Author Topic: injector pump on my tractor  (Read 1745 times)
sadman43
  • Northumberland
« on: 29 April 2008, 19:04:39 »
hi all it`s been a while,
can anyone help!! my injector pump is leaking I need the rubber seal that fit`s around the inside of the lid of the injector pump, i`ve been told off mr vauxhall that you have to buy a new pump as they don`t do spares for it, crikey are they taking the pee, a new pump for the sake of a rubber seal that would cost a few pounds, HELP :'(
rickyboy
  • Glasgow
Re: injector pump on my tractor
« Reply #1 on: 29 April 2008, 19:22:29 »
What about trying a breakers?
sadman43
  • Northumberland
« Reply #2 on: 29 April 2008, 19:27:43 »
thought bout that but they want £120 for a pump they`r not keen to just let me have the lid, wonder why. ha ha. cheers matey :)
Debs.
« Reply #3 on: 29 April 2008, 19:39:48 »
Is the the injection pump actually made by Bosch or another non-Vx manufacturer?....if so, what about a Diesel/Fuel-Inj. parts/service specialist who could supply just 'service' part (gasket) for the pump.  ;)
sadman43
  • Northumberland
« Reply #4 on: 29 April 2008, 19:45:28 »
Not sure bout that as only took the lid off and not the whole pump, but will check it out. cheers :)
rickyboy
  • Glasgow
« Reply #5 on: 29 April 2008, 19:51:14 »
Mabye try and get a hold of one that's broken so they won't be trying to sell on the whole pump.  Mabye try the wanted section in the forum or ebay.  I can't think of anything more annoying than having to replace a whole part for something like that.  Similar thing happened to me with a crack in the plastic part of my radiator - the rest of the radiator was in perfect condition and had to replace the whole part.  Good luck buddy.  :y
Omegatoy
  • UK
« Reply #6 on: 29 April 2008, 20:33:15 »
its a square ring, ring seal which any good bosch service centre should be able to get hold of have seen quite a few with the top dribbling but  usually  some carefully applied sealant round the outer edge of the seal cures it, not anywhere near the insides of the pump tho!!! :y
« Reply #7 on: 29 April 2008, 22:14:06 »
could try bmw or landrover.  Failing that, sealent
sadman43
  • Northumberland
« Reply #8 on: 05 May 2008, 18:18:02 »
got in touch with diesel bob he does a full seal kit for £35 + vat, think i`ll go for that. cheers folks. :)
