My ICE Project so far...
Started by tunnie, 19 July 2006, 17:07:53
Well after much thinking and several beers! I decided it was best to keep my Double Din unit. I was going to loose too much money on it replacing with single DIN.
So I decided make that unit fit, and work!
First problem was the cage as too big, almost half a cm!! Grrrr damn Vauxhalls. So I got some Tin cutters and cut the top off the cage, sorry there are not pictures of this, but in the heat and my frustation i thought it was not wise to have an expensive object near me!  ::)
So if you imaine a standard HU cage, i cut the top off so it only had 3 sides. After 2 cut fingers, some TCP and a plaster later it was cut down to size.
And it was still a !"&^$%! b!tch to fit in, in the end i used small blocks of wood about an 1inch sqaure and a mallet to get the damn thing in!! But i was worth it.
The headunit now slides in and clicks and holds were it should, here are some pictures of my progress so far:
After messing around with the settings, i got rid of the crappy animations that went on, horrible horrible animations. Looks better just displaying the track name
I have an Aux lead (RCA to headphone) jacking going to the glovebox
The Sub, this Vibe Active unit is amazing!! So powefull! with the boot closed and Ski hatch shut, it still feels like someone is punching the back of my seat!  :o
Please excuse the mess in the boot!
I have on order a facia adaptor, thats next on my list to modify so it fills the gap between the HU and the side buttons.
Markie
Thats looking good Mark
Would love to go at something like this for the Omega but need the boot space for the golf clubs  :(
Golf clubs!  :o
Plenty of room for them even with the Sub in there, depends how many clubs you want to take!
Pleased so far with the install, just getting the facia to blend in nicely is the troube.
That Vibe unit is so powerfull it vibrates the boot and the back bumper!  :)
markey mark
told you them vibe active subs are quality  ;) really punch hard  ;D
You could have taken those filters out and chucked them away - they've been there since Sat!
BTW, I have a spare sump plug now. Flipping expensive though (over £3 + VAT). Thieving bastards...
Martin_1962
QuoteThats looking good Mark
Oh dear - I'm not old enough for golf
You ain't got room anyway - you've filled your boot with LPG tanks....
B52
Does look like good kit and quite good in the car - don't think I'd have the patience! Although I did strip down a Senator heater control to replace a peanut bulb inside. Once.
QuoteYou could have taken those filters out and chucked them away - they've been there since Sat!
£3!! Gits!!
We can settle up on everything during the week?
I know about the stuff in to boot i forget about it, still got a BT Converse Phone in there with Plantronics Headset, why i leave that in the boot i don't know! Bit OTT as a car phone! ;D
I highly recommend the Vibe unit, wow! It really feels like some burly bloke is sitting behind me punching the seat!
Martin_1962
Only the one - 70l
Only the one - 70l
Valuable room for a set of clubs  ;D
hummm Golf Clubs or Active Sub.... hummmm ::)
Sub Sub Sub Sub Sub Sub  :)
nixoro
Smart bit of kit tunnie am I right in thinking your still using the standard door speakers, or do you have plans to get those upgraded aswell.
QuoteSmart bit of kit tunnie am I right in thinking your still using the standard door speakers, or do you have plans to get those upgraded aswell.
Still using standard door speakers, I find them to be excellent. Even better now with an after-market headunit.
No plans to change them, doing a brilliant job. Apparently they are much better when amped, but due to the lack of space behind the HU i won't be doing that, but really there is no need to. The standard speakers give excellent clarity and impressive bass.
nixoro
Maybe looking to do something similar eventually, granted the missus dont like that sort of thing, she says my current speakers are loud enough, but if the sound is improved with the sub I may go that way.
