Author Topic: Reading trouble codes on newer models  (Read 5984 times)
kcl
  • Finland
    • Volvo V60 D4 -14
« on: 06 May 2008, 11:10:13 »
Found this one on a Vecrta-forum. Doeas anyone have any idea will this (or something similar) work also for Omegas with Y26SE/Y32SE?
Quoted from "some forum":
To read ECM diagnostic trouble codes on the Bosch ECM for a 3.2 V6 petrol engine (Z32SE):
1.        Ignition off
2.        Fully press both the brake and accelerator pedals
3.        Turn key to Run (but not crank!) position
The MIL (engine malfunction light) will flash to indicate the trouble codes. The individual digits will be indicated by short flashes with a pause between digits. A longer flash will appear between trouble codes. At the end the light will stay on. If no diagnostic codes are stored the light will just keep blinking.
As an example, I disconnected the engine cooling fan connector. The following sequence of flashes appeared when the instructions above were followed:
1 long flash
1 short flash, 4 short flashes, 8 short flashes, 1 short flash
1 long flash
1 short flash, 4 short flashes, 8 short flashes, 3 short flashes
1 long flash
1 short flash, 4 short flashes, 8 short flashes, 2 short flashes
lamp stays on until pedals released
This can be interpreted as the following codes:
P1481 = Fan Control 1 Circuit
P1483 = Fan Control 3 Circuit
P1482 = Fan Control 2 Circuit
I'm pretty sure that this method will only read ECM trouble codes. For codes set by other modules you will still need some sort of specialised fault code reader tool (e.g. a Tech 2).
Also, this may or may not work on other engine controllers - I can only say that it works on the Z32SE controller.
Re: Reading trouble codes on newer models
« Reply #1 on: 06 May 2008, 11:38:05 »
i'd be surprised.....   .....3.2 owners care to try?
« Reply #2 on: 06 May 2008, 12:45:58 »
Interesting .... just tried this and the EML light flashed continuously !! Which seeems to agree with the above .. no faults !
Now, what would be the easiest and least "dangerous" to unplug to test out other aspects ???
Mike Collins
  • North of Bristol
« Reply #3 on: 06 May 2008, 12:49:14 »
Just tried it on my 2.6, the symbol of the vehicle with a spanner vertically flashes continuously until the pedals are released.
There does not apear to be any pattern, just continuous flashing.
I don't have any trouble codes stored.
jules
  • Edinburgh
  • Woke up this morning a post whore
« Reply #4 on: 06 May 2008, 12:52:41 »
I'd unplug either the maf, or the air temp
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
« Reply #5 on: 06 May 2008, 13:28:17 »
No air temp on the 2.6/3.2.....MAF would be a good one, front multiram would also be a safe one to unplug.
« Reply #6 on: 06 May 2008, 13:47:51 »
okies ... now remember I'm a dummy and get confused easily ..... I have unplugged and tried 3 different connectors.
1. Front end of cable tray
2. Clipped to top left of cam belt cover
3. Down behind the "trumpets", has a whiteish air-type line just above it
In all cases the EML light just flashed continuously ... :(
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #7 on: 06 May 2008, 16:18:48 »
Tried it on my 2.6 (manual, 02 plate). Now, the EML is on for me, as I posted in my other topic.
 Followed that sequence, and the light flashed out 10-4-3-10... then stayed off (for more than ten seconds)... and illuminated constantly when I lifted off the pedals. HTH
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #8 on: 06 May 2008, 16:21:17 »
So it works? Damn, this one was a good find  ;D
« Reply #9 on: 06 May 2008, 16:22:19 »
 Indeed. Now, what does 10-4-3-10 relate to?
    • 530D M Sport, 330i Coupe
« Reply #10 on: 06 May 2008, 16:22:41 »
Usual 3.2 pre cat problem then....  obviously beginning to effect a few 2.6's now.
« Reply #11 on: 06 May 2008, 16:25:27 »
 Hmm. Is this an excuse for me to fit a full stainless system? :)
« Reply #12 on: 06 May 2008, 16:27:57 »
Nope!
Have a search on here and you'll find the problem discussed a number of times. But basically 2.6/3.2 has 4 cats, the precats aren't up to the job after a few years use. Don't worry though because the car will still pass emissions tests due to the main cats being plenty good enough.  :y
« Reply #13 on: 06 May 2008, 16:31:15 »
Nope!
 Right. So it's not going to damage it to drive it? Is there any point getting the light reset, or will it come on again?
 (If it can be reset, I might bring my Omega down to WIM's open day, hint hint ;) )
 ETA: Read this topic - http://www.omegaowners.com/forum/YaBB.pl?num=1206389782
 Cheers chaps, really is appreciated, and puts my mind at rest. :y
« Last Edit: 06 May 2008, 16:32:44 by PeteG »
« Reply #14 on: 06 May 2008, 16:33:22 »
Yes can be reset, have to reset mine about once every two months.  ::)
