Author Topic: White headlamp lenses  (Read 2507 times)
meaney
  • newry. Northern Ireland
« on: 13 May 2008, 21:32:31 »
Is there any way of polishing the headlight lenses when they turn white over the years ?
The Barge Captain
Re: White headlamp lenses
« Reply #1 on: 13 May 2008, 21:38:58 »
I've heard of people using very fine wet and dry paper and getting results.
Otherwise get a set of projector lights from e-bay and directly swop.
(making assumtions here as it's usually only early models theat have this problem)
« Reply #2 on: 13 May 2008, 21:48:12 »
Follow on from wet n dry (1000 grit no coarser) with T-cut.
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #3 on: 13 May 2008, 22:17:04 »
I was going to try Brasso - following a comment on another forum for other cars with a similar problem..
(Waits for the flaming)
But my Mig's getting through nearly as much water as petrol at the moment, so it's suddently gone right to the bottom of my list..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
ARMYMPFromMO
  • Ft. Bliss, Texas, USA
  • Owns an Omega cousin, 1999 Cadillac Catera
« Reply #4 on: 18 May 2008, 03:10:11 »
To take care of that haze use a light rubbing compound. Don't use heavy duty. Tape off the surrounding area, I'm kind of particular, I taped everything about six inches away. Use a buffer and let it rip, moving the buffer constantly, up, down and sideways. This takes the heavy haze off. Follow up with a plastic polish, there are many out there. I use Meguiars products and went with their plastic polish. I wish I had taken a before and after picture. Perfecto!
Respectfully,
Lance
« Reply #5 on: 18 May 2008, 08:14:57 »
i would use 1500 wet and dry,or finer.
bighed
  • Shropshire
« Reply #6 on: 18 May 2008, 08:38:35 »
I agree, 1500 would br better. I think thou would be too coarse. T cut will bring them up lovely as said above  :y
