Author Topic: MY HEADLIGHT  (Read 1667 times)
DaviesEB
  • Monrovia Liberia
MY HEADLIGHT
« on: 19 May 2008, 09:18:51 »
Thanks to all who help get me diagnose my problem sometime back. I have sent for thr crank sensor.
One other question over time the headlamp glass looks dull. What can i use to clean it to give it the glass look.
Thanks :) :)
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
biker
  • Bradford
Re: MY HEADLIGHT
« Reply #1 on: 19 May 2008, 09:52:26 »
I used a fine cutting compound, used a soft sponge plenty of water as they do in body shops, comes up a treat.. ;) :y
comfortable at last
DaviesEB
  • Monrovia Liberia
Re: MY HEADLIGHT
« Reply #2 on: 19 May 2008, 09:58:45 »
What do you mean by cutting compound. Any particular type or make .
Thanks
Re: MY HEADLIGHT
« Reply #3 on: 19 May 2008, 10:00:57 »
Thanks
T-Cut is ok
DaviesEB
  • Monrovia Liberia
Re: MY HEADLIGHT
« Reply #4 on: 19 May 2008, 10:44:03 »
Thanks. I am located in Africa and we do not have such thing on our market. Can i get it in any store in the UK. Can you link me with a store where i can purchase same.
Thanks
Re: MY HEADLIGHT
« Reply #5 on: 19 May 2008, 11:02:59 »
T-cut will be available at any UK motor shop.
If it is yellowed a lot, T-cut may hot be harsh enough, you may need to start with a fine (1000) wet and dry, then go finer and finer, then finishing off with t-cut
DaviesEB
  • Monrovia Liberia
Re: MY HEADLIGHT
« Reply #6 on: 19 May 2008, 11:05:01 »
What causes the blurred look on the headlights. Is it the intensity of heat over a period of time? or What?
Thanks
