Author Topic: How to change diesel injector  (Read 1346 times)
alistair
« on: 18 May 2008, 17:35:58 »
I stupidly snapped off one of the small metal outlets for the spill pipe on one of my injectors.  Firstly how easy is it gonna be to change and secondly does anyone have one they'd like to sell me?
Many thanks
Alistair
Re: How to change diesel injector
« Reply #1 on: 18 May 2008, 21:45:49 »
Easy enough, need a bit 27mm socket.  Or if its the injector with the needle sensor, you need a special injector socket.  Oh, and a rather great long bar, as it will be pretty tight!
alistair
« Reply #2 on: 18 May 2008, 22:05:00 »
Its number 1 or number 6, whichever is the one at the rear of the engine.
Is there much fuel pressure that goes through the spill pipes?
Its the one thats blanked off which has snapped so i wonder if i can block the hole using some chemical metal?
« Reply #3 on: 18 May 2008, 22:12:40 »
Low enough to stop the pipes blowing off in use.  Try chemical metal and see what happens.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 19 May 2008, 21:29:17 »
I have a set of 6 injectors which have been checked by Bosch Agent in Newbury
They were used & not cheap to obtain
PM me if of interest
IW
Omegatoy
  • UK
« Reply #5 on: 19 May 2008, 21:32:20 »
Many thanks
Alistair
if as you say its the blanked off end one then screw a self tapper in to the hole after coating it wth chemical metal it wont leak and should never neeed touching again!!
Omegatoy
