Author Topic: Crankcase breathers, small one 2.0L  (Read 1460 times)
cannonfodder
  • Leicester
  • Never ever Blimin anything ever
« on: 20 May 2008, 17:17:53 »
Been having a few probs with my tickover, cleaned the IACV, and the small drilling underneath the butterfly. Discovered to my amazement that the smaller of the two breathers from the crank case, had actually been glued on, looks as if the pipe which it connects onto had broken off.  Not sure if the glue has obstructed the pipe, if so, what effect would this have on the car? thanks in advance
john
Re: Crankcase breathers, small one 2.0L
« Reply #1 on: 20 May 2008, 19:50:28 »
john
The crank case will pressurise on tickover......rather than running at a vaccum like it should.
cannonfodder
  • Leicester
« Reply #2 on: 21 May 2008, 17:10:21 »
are there any obvious symptoms of a crankcase pressurizing, I cant get to the other end of the pipe at the throttle housing just yet, to see if its blowing ?
