Author Topic: Car failed it's MOT for handbrake, need advice!!!!  (Read 1731 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« on: 26 May 2008, 21:30:47 »
Well the omega went in for it's MOT on saturday and failed on the handbrake, so today I thought I would take it apart to see what the problem was and it appears that the 2 pins which hold the handbrake shoes in place have ripped through the backing plate, and now the hole's are to big to fit new pins so do I need to replace the backing plate and if so how do I replace it.
The photo below shown the hole for the pins in red and the bolts for the plate are in yellow, do I have to remove the 4 bolts which are on the plate and remove the hub to change the plate.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Car failed it's MOT for handbrake, need advice!!!!
« Reply #1 on: 26 May 2008, 21:41:02 »
Not much help I'm afraid Jim but could you weld a washer in to allow the pins to be used on the old plate?
Seem to remember someone saying taking the rear hubs off was a pig of a job but I may be wrong.
TuBy's new whipping boy.
« Reply #2 on: 26 May 2008, 21:46:23 »
IIRC as long as the shoes are held correctly with the pins through the holes then it will pass.. Why not just put washers behind the pins?? I see no reason to weld them to the backplate.
« Reply #3 on: 26 May 2008, 21:50:44 »
Agreed ... fixed the cortina that way years back !!! It was a tad fiddly and involved cutting the washer so it could be bent "open" to get the t-piece through, then bending back to position and a touch of araldite to hold in position ....  add some "spray" underseal to hide it .. and it sailed through the MOT  :)
Jim
  • Glasgow
« Reply #4 on: 26 May 2008, 22:18:22 »
So do you think if I get a bolt the same length and diameter as the t shaped pin and put it through the the spring then through the handbrake shoe and then put a washer and bolt on the back of the plate to secure the bolt that should work, what do you think
« Reply #5 on: 26 May 2008, 22:29:52 »
You can't bolt the spring in .. it needs to move about ... the idea is to use a washer to make the worn hole back to its original size and stop the t-piece pulling through .. :)
« Last Edit: 26 May 2008, 22:30:14 by entwood »
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #6 on: 26 May 2008, 22:30:13 »
Think I'd be trying that Jim. As long as it's secure and working should be fine. Maybe use some thread lock on the nut so it doesn't come undone.
Jim
  • Glasgow
« Reply #7 on: 26 May 2008, 22:44:53 »
The problem I have with using a washer is that the original hole is not round, it's a slot shape, the blade on the bottom the of t shape pin goes through the slot then turns 90 degrees to lock it
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #8 on: 26 May 2008, 22:47:02 »
File or grind the slot into a washer then proceed as before?
« Reply #9 on: 26 May 2008, 22:48:39 »
yup ... if you bend a washer slightly then position it over the slot it still locks quite well, the dab of araldite was a sort of insurance .....
From my days of bodge it and keep it going ... money was tight and the car was needed ... I realised what the phrase "needs must" was all about !!!!
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #10 on: 27 May 2008, 21:00:25 »
Remember Jim.......
Safety is no accident.  :y
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
