Author Topic: new oil cooler old muck  (Read 1936 times)
bibbot
  • sutton sm39n
« on: 27 May 2008, 19:39:23 »
Iv just replaced the oil cooler , I flushed out the water but how much mao would you expect to find in the filler tank , I was surprised to find lodes of mao back in the filler tank
How many flushes before you find the tank not as full of mao as it was be for the oil cooler change
thanks
Re: new oil cooler old muck
« Reply #1 on: 27 May 2008, 19:47:07 »
When I did mine I replaced the coolant bottle and flushed the cooling system for weeks before the water ran clear.
Albus Dumbledore
  • Bergen, Norway
« Reply #2 on: 27 May 2008, 19:49:12 »
I've been flushing since March, and I still get som gunk:(
« Last Edit: 27 May 2008, 19:49:39 by AlbusDumbledore »
Danny
  • Wigan, Greater Manchester
« Reply #3 on: 27 May 2008, 20:04:49 »
still doing too many short journeys?
bibbot
  • sutton sm39n
« Reply #4 on: 27 May 2008, 20:15:57 »
so after one flush the filler tank can be full of mao  .
ok thats reassuring
thank for you input
ill keep flushing.
« Reply #5 on: 27 May 2008, 20:33:44 »
Try using some Forte in it, I went through 3 bottles, it will clear after a while :y
« Reply #6 on: 27 May 2008, 20:36:37 »
you will need at least 20 flushes....
mega3.0v6
« Reply #7 on: 27 May 2008, 22:53:34 »
When i did my O/C i used wynns rad flush left it in system for bout 50 miles flushed out with hose all clear now.
« Reply #8 on: 27 May 2008, 23:00:19 »
Is it worth worth putting wyns or similar products in the oil before an oil change to stop this problem, I keep hearing conflicking information regards these things and therefore have stayed well clear.
TIA   :y
