Author Topic: clicking sound  (Read 1279 times)
t falzon
  • croydon
clicking sound
« on: 04 June 2008, 10:32:00 »
hi my 2.5 v6 as started to make a strange clicking sound from engine sounds lie when i was young and put lolipop sticks in bycle wheels told that will cost me £1000 to put right as the engine as to come out toput neww gaskets on exhust manifolds is this right or can it be done another way
Re: clicking sound
« Reply #1 on: 04 June 2008, 11:09:23 »
Does the sound lessen as it warms up?
If so, probably exhaust manifolds.
The engine doesn't need to come out to change them (unless perhaps a stud has broken - even then taking the cylinder head off would be easier).
The accepted wisdom seems to be to replace only with multi-layer steel gaskets, not pattern composite gaskets as they don't last.
t falzon
  • croydon
Re: clicking sound
« Reply #2 on: 04 June 2008, 11:13:23 »
thats what they said is on there and they reckon the metal layers come apart as to wether the sound goes when hot sometimes when on long jorney
Re: clicking sound
« Reply #3 on: 04 June 2008, 11:54:10 »
Well the metal layer ones were never fitted from the factory......so unless they have been changed in the past.
Drivers side manifold gasket takes about 3 hours, apssengers about 2-3 hours (but these rarely fail).
Its worth checking the EGR corrugated pipe is secure also before doing anything
Markjay
  • London
Re: clicking sound
« Reply #4 on: 04 June 2008, 15:01:15 »
Ahmmm... that's MarkDTM's times... mere mortals might find it takes slightly longer....  ;D
Alas, no more Omegas....
Re: clicking sound
« Reply #5 on: 04 June 2008, 15:10:18 »
And mechanic times......
