Author Topic: LPG running lumpy and engine management light  (Read 2817 times)
ben1975
  • West London
« on: 01 June 2008, 23:14:42 »
hello all, i need some advice on my 3.0 elite.
I have been having some issues with my omega, when it starts the idle is slightly lumpy, and when u switch to LPG the lumpyness is more pronounced, and sometimes when its warm the engine management light goes on and off. But as soon as you accellerate it runs really smooth.
Has anyone got any ideas on what it could be?
I am not that technically minded i am afraid, can anyone give me some advice, or reccomend a garage i can take my car to that deals with LPG in the west london area, i am prepared to go up to 80 miles to get it sorted?
Do any of you do servicing of omegas and will try and sort out my LPG?
as i am driving to france in august and i would really like it sorted.
Re: LPG running lumpy and engine management light
« Reply #1 on: 01 June 2008, 23:38:22 »
I reckon it's an issue with the spark... LPG needs the ignition system to be in top condition.
Just a guess as I've just nipped in to check messages before bed!! 5am start fro work tomorrow  :( :( :(
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #2 on: 02 June 2008, 07:14:03 »
Lazydocker is right, i would start with ignition, LPG will highlight any issues like that.
Whereabouts in London are you?
« Reply #3 on: 02 June 2008, 11:58:32 »
Seeing what codes are stored would be the first step in the right direction...
Danny
  • Wigan, Greater Manchester
« Reply #4 on: 02 June 2008, 14:41:06 »
mine suffered these symptoms, but it had new plugs the day it went in for conversion, but my lumpy idle was gas only, ran fantastic on petrol
the EML would come on at low revs, and at low throttle at higher speeds, and it was because it was running too lean, no fault codes were stored at all, mine was never cured 100% but was vastly improved when the mixture was enrichened, my main problem is that my injectors had been fitted at the front of the plenum "to look tidy" which i was never too happy about in the first place, i would imagine yours are at the sides of the plenum for a more direct feed?
mine's having the manifold repaired and the injectors re-situated
rickyboy
  • Glasgow
« Reply #5 on: 02 June 2008, 19:28:31 »
Paper clip test to get the codes and got to agree with Lazydocker - most likely plugs and leads need changing.
« Reply #6 on: 02 June 2008, 21:57:55 »
If I'm right, the only errors which may show up should be Lambda related I think. Caused by over fuelling in the cat due to the misfire.
I'd be fairly happy to suggest changing plugs and leads, as per the other suggestions, as this will probably cure the problem.  :y :y
ben1975
  • West London
« Reply #7 on: 03 June 2008, 22:51:14 »
i have had the dis pack and the leads and plugs changed not that long ago, do i need to get a certain type of plug to work with the LPG?
does a particular make of plug make a difference?
i am in west london, near twickenham by the way
rickyboy
  • Glasgow
« Reply #8 on: 04 June 2008, 09:56:09 »
You can get plugs specifically for lpg cars but I've personally never used them and they are awfully expensive.  I wouldn't bother though if you've recently changed dispack, leads and plugs then I doubt your problem lies there.
Does this car have an idle control valve?  If it does then give it a clean and lubricate it.  Also clean the throttle body and surrounding breathers and that should fix the lumpy idle.
If you notice an improvement only on petrol then it's mabye time for a re-tune of the lpg and mabye even a service on the vapouriser.  Clean the throttle body and icv first though.
rickyboy
  • Glasgow
« Reply #9 on: 04 June 2008, 09:58:30 »
We still need you to do the paperclip test so we can tell why your engine managment light is on.  Follow this guide and post the results before you go any further...
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
ben1975
  • West London
« Reply #10 on: 04 June 2008, 11:45:19 »
ok i will do the paperclip test and let u know. Is there any guide on here to tel me how to clean the throttle body and breathers and to see if there is an idle control valve?
as i am crap with car engines and i would not know where to start LOL
But thankyou everyone for all your help so far, its nice to get some feedback from people who know what they are talking about!
« Reply #11 on: 04 June 2008, 11:49:47 »
SOunds like an airleak to me but, lets see what the codes say
ben1975
  • West London
« Reply #12 on: 04 June 2008, 19:38:52 »
hello again all, i tried to do the paperclip test, and when u put the paperclip it flashes a couple of times, then flashes loads of times then flashes slowly again.  But is it supposed to stop at any time? as it keeps on flashing for ages and ages lol
can some pls give me an idiots guide on how long i am supposed to count for
i am really sorry i am being so thick
« Reply #13 on: 04 June 2008, 19:57:33 »
"Paperclip" instructions can be found here .. :
follow the link UNDER the photo and you'll get a short video example
« Last Edit: 04 June 2008, 19:58:38 by entwood »
