Author Topic: tyre wear / suspension adjustment  (Read 3538 times)
shanjon
« on: 27 May 2008, 00:42:31 »
my front tyres are wearing out on the inside edge, what im wondering is does anyone know what needs adjusting , im planning a trip to wim when funds allow but im thinking i could manually adjust something myself for the time being to slow the amount of wear, as my tyres have 5mm across the rest of the tread and are almost through to the metal on the inside edge
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: tyre wear / suspension adjustment
« Reply #1 on: 27 May 2008, 01:42:30 »
In my experiennce it has been tracking or camber that needed adjustment. but worn front wishbone bushes could also be the problem.
JezInBrum
  • Birmingham
  • Built for comfort not speed
« Reply #2 on: 27 May 2008, 02:44:50 »
About to change my wishbones. First signs were when braking steering seemed to wander/pull slightly & need slight correction. Only really clocked extent of problemwhen i caught a glimpse of inner edge of tyre when car was parked up. Was through to steel & canvass in parts.Been parked up since waiting for new wishbones to land.
MikeDundee
  • Costa Del Peckham
« Reply #3 on: 27 May 2008, 07:02:58 »
Have a read of this thread aswell :y
http://www.omegaowners.com/forum/YaBB.pl?num=1211651944
I had a similar if not the same problem as yurself, had the geometry done on the car and appears to be OK now :y
« Reply #4 on: 27 May 2008, 08:32:29 »
may need new wishbones, did all that on my 99 cdx. Do the rear joint first, i seem to remember. First i knew of prob was a ting ting ting when driving along. Only had car a couple of weeks, so did not know how it should feel at the wheel, but it was pulling majorly to the left. Ran my hand round inside edge of the tyre and was promptly stabbed in the hand by a bit of wire! It was waking the bottom of the spring cup. I had guessed shock replacement had not been done correctly on that corner as all 4 tyres where the same and half worn and other 3 where all fine.
 New tyre and laser wheel alignment at Michledever tyres sorted it. The guy showed me, it was so far out the top  of the tyre sidewall had been rubbing on the shock.
 Completely dif. car afterwards, less twitchy drove straight, lovely. I still find omega steering a bit vague tho?
 Anybody got thoughts on that?
Did the wishbones 40k later as bushes where well low, and took it back to laser
up. It was miles out, as you would expect.
 So, my thinking, ANY work on your suspension, Get it checked for camber caster and trail as well as tracking.
  It could well save you 2 front tyres.
The number of tyre people i spoke to about the problem that said get the tracking done! Bloody tracking was fine, it was everything else that had gone to cock.
 WIM IT ASAP, happy motoring.
« Last Edit: 27 May 2008, 08:39:43 by chrisgixer »
v6coop
  • Nottingham
« Reply #5 on: 27 May 2008, 12:52:01 »
Check out the steering idler arm for play whilst you are at it (on the near side). If this has failed you also get strange handling (very prone to tramlining) which causes you to constantly adjust the sterring wheel. This too will cause or add to the inner edge tyre wear.
v6coop
  • Nottingham
« Reply #6 on: 27 May 2008, 12:55:51 »
Forgot to mention that Lemfoder manufacture the original wishbones and steering idler for Vauxhall I believe. You can buy the wishbones for £50 each from Autovaux as opposed to £200 (retail) from Vx.
shanjon
« Reply #7 on: 31 May 2008, 01:17:36 »
well i have bitten the bullet and ordered 2x new wishbones, 2 new droplinks and 2 x complete track rod ends, and while i was there new front discs and pads, ,
there is a slight knock coming from the front somewhere when i start to brake and the other day when pulling off of a kerb i was getting a strange creaking noise so i hope the new bits will fix it  [smiley=undecided.gif]
it better my mot is due in a little over a week, and yes i was planning having the geometry done after
davlad22
  • Sunny Yorkshire
« Reply #8 on: 31 May 2008, 02:12:29 »
Ooooh, creaking noise could be a broken spring, they often break (given the fabulous state of our roads), the last inch or two which sits in the 'cup' on the strut assembly. Have a little poke around, just a thought.....but then, it could have just been flex in the body. Our estate creaks a little sometimes when towing.
shanjon
« Reply #9 on: 31 May 2008, 15:09:54 »
i have only heard it the once i assumed it was  a rubber bush in the wishbone or summat , but i will check the spring
« Reply #10 on: 31 May 2008, 15:42:51 »
Well, inner tyre wear is a camber issue.....
You could as a temporary setup apply a more positive amount by slackeneing the two lower strut to hub bolts off and pulling the hub upright (the top hole is slotted) and then back them off 2mm ish.......it wont be spot on but will slow the inner tyre wear as a temporary measure only.
Then get is set properly. :y
« Reply #11 on: 31 May 2008, 19:45:00 »
Shoulder wear is always camber, as suggested.  Worth getting sorted before tyres get wrecked.
shanjon
« Reply #12 on: 31 May 2008, 22:17:40 »
excellent m8  :y  im with ya , so basically pull the suspension leg towards me as i look at it and it should give me either roughly about right or wear the outside edge (but hey at least id get to use more of the tyre lol)
 i will fit the new wishbones first and then try to adjust it roughly, my aim is to get it booked in at WIM asap,well when funds allow
JasonH
« Reply #13 on: 01 June 2008, 09:12:24 »
If you're going to change the wishbones it is much easier if you unbolt the strut (i.e. the two bolts that also do the camber adjustment).
If you do this you will destroy any original camber setting (which sounds miles out anyway). But then you could set it roughly anyway.
If you can't get to WIM (the best) if you can get to someone who has computerised 4 wheel alignment and tell them the settings you want (NOT LET THEM USE THE MANUFACTURERS FIGURES) you probably be fine.
You're looking for a camber of around -1 deg 10 mins to -1deg 20 mins each side. And personally I set the toe in to close to the +ve limit (max toe in) which in mm is +0.9mm a side. Makes the car drive beautifully.
Correct suspension adjustment makes a huge difference to tyre wear, ride and handling on an Omega.
Mr_P
  • Nottingham
« Reply #14 on: 01 June 2008, 09:59:00 »
If in Notts with this camber issue where would the best place be to take it?
« Last Edit: 01 June 2008, 10:49:55 by Mr_P »
