Author Topic: car stuck in park  (Read 1878 times)
War-Planner
  • Warrington
car stuck in park
« on: 05 June 2008, 10:16:12 »
got in car this morning tryed to move gear stick it would not budge any ideas    :-/
Re: car stuck in park
« Reply #1 on: 05 June 2008, 10:19:04 »
There's a manual release down behind the gaiter for if/when the solenoid fails , if memory serves me correctly.  I can't check the handbook as SWTSMBO has the car but I'll check Haynes and get back to you ASAP
OK
typing exactly what it says in Haynes :
"carefully unclip the selector lever gaiter from the top of the centre consol, the depress the yellow  release lever on the left hand side of the selector lever with a pen or screwdriver. The lever can then be moved as normal"
HTH
« Last Edit: 05 June 2008, 10:21:45 by entwood »
« Reply #2 on: 05 June 2008, 10:22:18 »
Are the brake lights working?
Sounds like the brake swithc is a possible, as a work around, pop the gear lever boot off and press the release clip to get it out of park
Kieran
  • Dorset
« Reply #3 on: 05 June 2008, 10:25:07 »
Yes there is a manual release under the gaiter. You have to prise the complete cover up then you will see a way of releasing the gear handle by lifting up a small lever at the bottom
War-Planner
  • Warrington
« Reply #4 on: 05 June 2008, 10:29:43 »
cheers thx will look    :y
War-Planner
  • Warrington
« Reply #5 on: 05 June 2008, 11:03:52 »
thx got it sorted out can move gear stick now  ;D ;D ;D ;D :y
Mike Collins
  • North of Bristol
« Reply #6 on: 05 June 2008, 13:16:20 »
Check the microswitch that senses that the lever is in park. If its contacts become high resistance you will have increasingly frequent failures.
It's in series with the release solenoid.
Same part is used on the Vectra if you need to find a used one.
