Author Topic: auto box swap  (Read 1186 times)
oilee
  • Coventry
auto box swap
« on: 05 June 2008, 16:29:22 »
help folks, i am in the process of taking poccession of  3.0lt V6 elite with blown engine.
My question is this, can i put the ar35 auto box from this car into my 2.5 diesel with ar25 box. Mine has the beemer motor in.
I may well have bits for sale once i've had what i want so if you need something let me know and i'll see if i can help
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: auto box swap
« Reply #1 on: 05 June 2008, 16:31:04 »
I believe you can fit an ar35 box to either a 2.5 or a diesel....
Sure someone will be along soon to confirm  :y
Re: auto box swap
« Reply #2 on: 05 June 2008, 17:31:27 »
It will fit the TD, but you'll need to use the TD bellhousing :y
Omegatoy
  • UK
Re: auto box swap
« Reply #3 on: 05 June 2008, 20:02:52 »
and the tc!!!!!!
Re: auto box swap
« Reply #4 on: 05 June 2008, 21:10:19 »
yup, as Mr TD, Omegatoy, says, it will fit, reuse your td torque converter and bellhousing.  Downside is ar35 is slightly higher geared in 4th
oilee
  • Coventry
Re: auto box swap
« Reply #5 on: 05 June 2008, 21:24:32 »
so if i've got this right when u say use TD bell housing and torque convertor your refering to using the ones from the 2.5. so i can just put the 3.0 box straight on? wot about pipes and cables, electrics etc. wot difference will it have economy. all info gratefully recieved, many thanks
Re: auto box swap
« Reply #6 on: 05 June 2008, 21:48:46 »
Yes, remove ar25 (with bellhousing and tc). Remove bellhousing and tc and fit to ar35, refit ar35.
Electrics, pipework, etc all identical. May have to change a bracket that holds exhaust in place, but easy enough.
I do a rather horrid 40 - 55mph journey in, I tend to lock mine in 3rd for best economy.
