Author Topic: Crank sensor fault  (Read 1052 times)
valliant72
  • London
Crank sensor fault
« on: 05 June 2008, 23:35:08 »
Hi, after doing the paper clip test, it came up with the code 19 fault, thanks to members on here for putting me right on the code. Crank sensor is on order as VX didnt have stock, but is it the sensor failing which is causing the loss of power?
carlos_fandango
  • Stoke On Trent
Re: Crank sensor fault
« Reply #1 on: 05 June 2008, 23:42:39 »
It sure will be, puts the car into "Limp Mode"
« Reply #2 on: 06 June 2008, 09:33:10 »
car will run like a sack of spuds with a duff crank sensor
