Author Topic: X30XE "Choclate Engine"  (Read 8129 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« on: 05 June 2008, 13:52:41 »
where i work we share our building with the local police and i was talking to one of the Traffic cops
i was in the omega and he was talking to me about it i said it was an MV6 and he said very nice car that the 3litre lump is a choclate engine though i asked him why and he said that when they used to have them on the force they were very easy to blow up
he said in a motorway persuit they would overheat and stuff and they dont like being raced around town much
he said i should save my pennies and get a 3.2 as its a much better engine!
but i have never heard of a v6 vauxhall engine blowing up apart from tbelt failiures i always thought they were a good solid lump!
    • 530D M Sport, 330i Coupe
Re: X30XE "Choclate Engine"
« Reply #1 on: 05 June 2008, 13:58:46 »
The 3.2 / 2.6 have a steel crank so are supposedly stronger.
« Reply #2 on: 05 June 2008, 14:05:38 »
Hmm. very little difference other than the cranks, I thought, so unless they were breaking them it sounds suspect. :-/
You've only got to watch road wars to see how they're driven - never change up until it's bouncing off the rev limiter, etc. They decide if your driving style is going to inflict the same grief on the engine.
I would have thought the "vollgasfest" tests would have ironed out any bugs - it killed off the V8 Omega, as legend has it.
« Reply #3 on: 05 June 2008, 14:09:06 »
Doesn't sound right.....and only the 3.2 had a steel crank, the 2.6 does not.
And the crank does not affect the heat of the engine!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 05 June 2008, 14:12:46 »
i know on the VVOC Vaux Vec OwnersClub a guy carried out a turbo conversion on a 3.0 v6 and h tried putting 3 bar boost through it and blew the conrods to pieces but most engines without extensive results would do the same!
as for over heating all vauxhalls run hot and its a vauxhall trait in my opinion!
your right about roadwars though thrashed constanly especially Pat he seems to like the limiter bouncing about abit
« Reply #5 on: 05 June 2008, 14:29:10 »
 ;D 3 bar of boost on an engine that has cast pistons and stock compression ratio is only going to end in tears.
I don't believe running hot is a trait. A modern engine runs, on the whole, at the temperature determined by the thermostat / fan switches.  Unless the cooling system is really in a bad way it won't stray outside these limits in our climate. You might start to find weaknesses as you tune an engine, but left stock they've got huge reserves of cooling over what's normally required.
A Ford Zetec engine runs at around 100 degrees C on the manufacturer's thermostat (doesn't start opening until 98).
I suspect plod vehicles suffer from the "not my car" syndrome. (We've all done it in pool cars / hire cars. Imagine it when you are "the law" and are unlikely, therefore, to get nicked.)
Markjay
  • London
« Reply #6 on: 05 June 2008, 18:11:58 »
There can be many reasons why the Omegas used by your local police force overheated, from infrequent coolant changes, use of wrong coolant, neglected HBV valve leaks, neglected oil coolers leaks.... but none are integral to the engine.
I ran two V6 omegas for a total of 10 years and 100k miles between them, one was a 2.5 the other a 2.6, and while I did not break them I must also say that I have never ever had a occasion where the engine over heated... but then they were properly maintained.
Alas, no more Omegas....
« Reply #7 on: 05 June 2008, 19:41:00 »
After seeing my local force in action, taking speed bumps at speed to count the air time, the gouges in the road and the biggest sparks they can create (with massive smiles on thier faces and giggling with fits of laughter as they land) then no wonder they dont like being raced round town, lets face, the average driver does not use the car on the rev limeter in normal or even fast road use.
When the average motorist pays his own repair bills, or the company monitors a reps repair bill then questions are asked.
But with Police cars they have to be maintained regardless of cost, so I bet there are NO questions asked because they have to be repaired regardless.
Based on the above the cars get abused (allededly) but if they drove by example as they should there would be a lot less problems, if they drove them in accordance to the law like we have to there would be more reliability.  Admitted there are the high speed chases etc, we all watch road wars, I bet there are not as many failures due to high speed pursuits as there are failures caused with regards to poor driving.
Why do they fail, apparently they are often abused.
Why are they often abused, because they know they can.
Lets face it, if you had the chance of driving a company car with "repaired at regardless of cost option" what would you do.
[size=8]Admin, if this post causes any concern for the forum, then please just delete it.[/size]
Humpy
  • Tunbridge Wells, Kent
« Reply #8 on: 05 June 2008, 20:04:11 »
So what's a crankshaft made out of if it's not steel? :-?
Humpy
« Reply #9 on: 05 June 2008, 20:06:42 »
After seeing my local force in action, taking speed bumps at speed to count the air time, the gouges in the road and the biggest sparks they can create (with massive smiles on thier faces and giggling with fits of laughter as they land) then no wonder they dont like being raced round town, lets face, the average driver does not use the car on the rev limeter in normal or even fast road use. .......
A bit like? ....http://www.omegaowners.com/forum/YaBB.pl?num=1212548105  :-X
« Reply #10 on: 05 June 2008, 20:48:05 »
Ah right, I knew the 3.2 did and just assumed that as the 2.6 was produced at the same time they would also use a steel crank.
Presumably GM deemed that it wasn't necessary on the 2.6?
I wasn't saying the crank affected the heat of the engine (i'm not that stupid despite appearences!  ;D), merely that the steel crank is supposedly stronger.
Cast from ductile iron apparently.... http://en.wikipedia.org/wiki/Crankshaft#Construction
« Last Edit: 05 June 2008, 20:54:14 by VXL_V6 »
« Reply #11 on: 05 June 2008, 21:13:19 »
Sadly, Yes
hotel21
  • The Kingdom of Fife
« Reply #12 on: 05 June 2008, 22:39:35 »
Agreed.
Hence why I personally would not buy one thats been used extensively on general patrol.  Ex central driving school, perhaps, but not one thats been the plaything of many.....   ;)
« Reply #13 on: 05 June 2008, 22:57:58 »
Humpy
cast iron presumably  :-/
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #14 on: 06 June 2008, 07:44:49 »
Fastest car/van in the world is a rental car  ;D
