Author Topic: 48   Battery Voltage Low!!!  (Read 1033 times)
vrba
  • Croatia
« on: 08 June 2008, 13:13:14 »
done te paper clip test and got the error 48 battery voltage low.
done the test while engine was not running abd when it was running and error is the same. what it could be?
Re: 48   Battery Voltage Low!!!
« Reply #1 on: 08 June 2008, 13:20:50 »
Measure the voltage across the battery terminals with the engine running.
Its normally an indication of a failing alternator
Failing that, check the main earth points.
vrba
  • Croatia
« Reply #2 on: 08 June 2008, 13:23:08 »
could this lead to my always running vents
