Author Topic: Fault Codes - O2 sensor...  (Read 3004 times)
Danny
  • Wigan, Greater Manchester
« on: 08 June 2008, 20:43:38 »
Captain Zok just had a look at my car and hooked up his laptop to it (much appreciated) and the codes that came up are
38 - O2 sensor 1 circuit voltage low
98 - O2 sensor 2 circuit voltage low
anyone able to tell me where to go from here??
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Fault Codes - O2 sensor...
« Reply #1 on: 08 June 2008, 21:15:37 »
You're welcome mate.
To add to this I cleared those stored codes which were showing as not present.
We took it for a quick run up the ring road and the 38 returned on accelleration EML seemed to be flickering then went off as Danny eased off the throttle.
TuBy's new whipping boy.
« Reply #2 on: 08 June 2008, 23:16:18 »
Do they recurr when running on petrol only or just on LPG?
rickyboy
  • Glasgow
« Reply #3 on: 09 June 2008, 09:53:03 »
I'd check the wiring from the o2 sensor to the lpg ecu (o2 sensor end).
Danny
« Reply #4 on: 09 June 2008, 10:38:52 »
thinking about it, didnt think to clear the codes then run it just on petrol, but i've ran the car on petrol now and again and never had the EML come on
« Reply #5 on: 09 June 2008, 11:59:07 »
Hmm. I would try clearing it and running it on petrol for a while. See if it comes back. Then switch to gas.. It could well be that the mapping for the LPG is out at a certain level of engine load, and it is unable to pull the fuelling back in.
