Author Topic: Air Conditioning - Low Pressure Side  (Read 1180 times)
Albert1
  • Herts
« on: 09 June 2008, 15:34:02 »
Going to be checking the pressure of the gas in the A/C system, can anyone confirm that [on the 2.5 V6] the Low pressure side is the pipe near the top of the engine, to the right of the plenum (when viewed from in front of the car looking at the engine) near the scuttle/pollen filter?
Thanks in advance.
Re: Air Conditioning - Low Pressure Side
« Reply #1 on: 09 June 2008, 15:45:05 »
Yep. low pressure pipe is the higher of the two in the engine bay. It;'s also the one that gets cool when air con is running.
Actual low side pressure is likely to be highly dependant on temperature but will give you an idea if there's a decent charge in it.
Matchless
  • Nottingham
    • A white van
« Reply #2 on: 09 June 2008, 16:31:59 »
A full charge with a cool system (an hour or two after engine last run) will give around 75psi (engine off)
With engine and a/c running the compressor should pull this down to close to 30psi and hold a constant pressure.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 09 June 2008, 16:58:49 »
dont use them crap cans from hellfrauds they are useless and cost £50 and they dont work!
