Author Topic: 2.5 1999 v6 cdx (wasnonstarter) clip test results  (Read 1022 times)
fredthedog
  • Ipswich
  • Big is beautiful...
« on: 10 June 2008, 22:01:15 »
Hi all, further to my previous post, paper clip test results:
12 12 132 132 132 132 12 12 (running)
12 12 132 132 132 132 31 31 31 12 12 (ign on/ notrunning)
Any advice greatfully received, no flashing dash lights, only non starter the other day (it started eventually, i did clean a very oily crank sensor if this could have been the problem).
how longs do faults remain logged??
thanks.. Nigel
Re: 2.5 1999 v6 cdx (wasnonstarter) clip test results
« Reply #1 on: 10 June 2008, 22:05:10 »
The 132 i flagging an issue with the EGR valve position.
Assuming the connector is on then its worth taking it off and cleaning the passage ways with a bit of paint stripper and checking its moving ok
