Author Topic: Need help with fault codes  (Read 4604 times)
MAX
  • London
« on: 11 June 2008, 20:35:49 »
I have just done a paper clip test and got the following code 10 then 3 then 4 then 10 again can anyone tell me what this means before i done the test the chap at the garage reckons i need a new crank shaft sensor do you think this is right. Thanks :y :y
rickyboy
  • Glasgow
Re: Need help with fault codes
« Reply #1 on: 11 June 2008, 20:40:52 »
You need a new camshaft sensor not crank sensor.  You could try cleaning it and its mating surfaces first.  If not replace.  Has your timing belt been changed recently?
MAX
  • London
« Reply #2 on: 11 June 2008, 20:42:57 »
yes about 2 months ago
rickyboy
  • Glasgow
« Reply #3 on: 11 June 2008, 20:46:29 »
Has the engine management light been on since the cambelt change?
MAX
  • London
« Reply #4 on: 11 June 2008, 20:49:03 »
no but it did come on for a few mins so the guy at the garage cleaned out the throttle body cause i was losing a bit of power and that seemed to sort it out and i have just been down to somerset with no probs :y
rickyboy
  • Glasgow
« Reply #5 on: 11 June 2008, 20:56:04 »
It could be that the sensor has failed or it may be that the sensor has just not been torqued up properly or could be a problem with the timing.  The fact that the belt has been changed so recently kind of points towards the timing.  Did he change the tensioners as well (very important in these cars) and that the indicator is pointing at the right part for old or new belts?
MAX
  • London
« Reply #6 on: 11 June 2008, 20:58:38 »
would the tensioners come with the cam belt kit?
rickyboy
  • Glasgow
« Reply #7 on: 11 June 2008, 20:59:24 »
Just to add...
...when the EML (Engine Management Light) was on after he changed the belt it probably was the camshaft sensor at fault.  You lose power when the EML is lit because it sends the car into LOS (Limited Operation Strategy) mode.
Cleaning the throttle body is a good idea anyway - you probably would have needed it done at some point.  Can't help thinking though that the timing may need checked.
rickyboy
  • Glasgow
« Reply #8 on: 11 June 2008, 21:00:35 »
Tensioners would come with a full cambelt kit, so they should have been changed at the same time.
MAX
  • London
« Reply #9 on: 11 June 2008, 21:02:59 »
i did get the full kit fitted, do you think it is worth getting the camshaft sensor done anyway as i have booked it in for tomorrow
rickyboy
  • Glasgow
« Reply #10 on: 11 June 2008, 21:10:08 »
Depends on how much it is going to cost really.  I'd hate to say yes when there is a possibility there is nothing wrong with the sensor itself.  The camshaft sensor is prone to failure on the 2 litre but the sensors do serve a purpose so when the ecu logs a fault it's not always just a case of a faulty sensor.
When you had the cambelt changed, was it changed due to the EML being on or just changed at its interval?
MAX
  • London
« Reply #11 on: 11 June 2008, 21:14:12 »
it is gonna cost about 80 quid, just changed at an interval :y
« Last Edit: 11 June 2008, 21:15:09 by jhchap9 »
rickyboy
  • Glasgow
« Reply #12 on: 11 June 2008, 21:20:48 »
If you do get the sensor changed make sure it is a genuine vauxhall sensor as the generic ones can often fail from new.  I'm still a little suspicious that the camshaft sensor code has only appeared after the recent timing belt change.
MAX
  • London
« Reply #13 on: 11 June 2008, 21:23:58 »
maybe i should have said this earlier but i booted it to work this morning in sport mode and it was after this that it happened
rickyboy
  • Glasgow
« Reply #14 on: 11 June 2008, 21:36:58 »
Did the EML come on at about 4500rpm?  If so it does sound like the cam sensor.  If you have the cam sensor replaced tomorrow and the light goes out and stays out you'll know it's the sensor.  It is worth getting the sensor changed as it is a common failure on the 2 litre.  If the light comes back on though you'll need to get the timing checked.
