Author Topic: Camshaft Position Sensor !  (Read 1230 times)
marinis69
  • Ashford
« on: 12 June 2008, 00:58:20 »
Hi. I was just cleaning oil on camshaft covers and removed the sensor. After that it wont start. Next day it was ok until i turned the engine off. after couple hour it will start again. I am sure i have installed the sensor as it was. Today mornin started the car, went to work and its dead now. I have checked it makes no sparks, not suplying fuel as well. Does it makes any sense that I have damaged the sensor accidently ??? Or it might be something else???
marinis69
  • Ashford
Re: Camshaft Position Sensor !
« Reply #1 on: 12 June 2008, 01:00:15 »
Done paper clip test and it came up with 12 and 31. Nothing else.
rickyboy
  • Glasgow
« Reply #2 on: 12 June 2008, 07:37:46 »
Could be the crank sensor - you won't get any codes up because you can't flash them with the engine running.  Check the wiring and plugs are connected correctly as I think the camshaft sensor connects to the crank sensor (from memory) but don't quote me on that.
