Author Topic: SAI system...  (Read 1354 times)
Vaughan
  • Exmouth, Devon
SAI system...
« on: 07 June 2008, 18:15:47 »
I'm having abit of trouble with the SAI, can I remove this system completely and will it affect anything once removed?
I am thinking that with all the pipework for this out the way, cambelt changes might be a little easier :-)
Re: SAI system...
« Reply #1 on: 07 June 2008, 19:00:04 »
Ive removed mine and blocked the hoses either side and disconnected the pump under the wing. It runs fine :y
Re: SAI system...
« Reply #2 on: 07 June 2008, 19:12:44 »
You need to keep the solenoid in place to keep ecu happy. Obviously any open pipes need to be blocked as well.
Vaughan
  • Exmouth, Devon
Re: SAI system...
« Reply #3 on: 08 June 2008, 16:29:11 »
Thanks for the replies. I asume I can "unscrew" the pipes from the manifolds and blank them with a short bolt with the same thread. What are the thread sizes I should get hold of?
TheBoy, do you mean the EGR solenoid?
Re: SAI system...
« Reply #4 on: 08 June 2008, 16:55:15 »
No, the solenoid if for SAI. Sits near rad/battery, has vac pipes going to it. If you follow pipes from SAI pump, you'll see it :)
Vaughan
  • Exmouth, Devon
Re: SAI system...
« Reply #5 on: 08 June 2008, 17:06:55 »
Yes I know what you mean now, found it. I'll leave that plugged in :)
Vaughan
  • Exmouth, Devon
Re: SAI system...
« Reply #6 on: 14 June 2008, 12:56:27 »
Is there a fuse for the SAI I can remove for the time being, until I can get under it to remove the system?
