Pages: [1] 2 3  All   Go Down
Author Topic: VERY Important Fuel Tips.  (Read 5539 times)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« on: 12 June 2008, 23:19:09 »
Some of you guys may have seen this email BUT..its a VERY interesting read and it seems logical. With our 2.5 and 3.0 V6's it could save a packet.
"I don't know what you guys are paying for petrol.... but here in Durban we are also paying higher, up to R7.35 per litre. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every litre.
Here at the Marian Hill Pipeline where I work in Durban, we deliver about 4 million litres in a 24-hour period thru the pipeline.  One day is diesel the next day is jet fuel, and petrol, LRP and Unleaded. We have 34-storage tanks here with a total capacity of 16,800,000 litres.
Only buy or fill up your car or bakkie in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the fuel, when it gets warmer petrol expands, so buying in the afternoon or in the evening....your litre is not exactly a litre. In the petroleum business, the specific gravity and the temperature of the petrol, diesel and jet fuel, ethanol and other petroleum products plays an important role.  A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode. If you look you will see that the trigger has three (3) stages: low, middle, and high. In slow mode you should be pumping on low speed, thereby minimizing the vapours that are created while you are pumping. All hoses at the pump have a vapour return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapour. Those vapours are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your tank is HALF FULL.  The reason for this is, the more fuel you have in your tank the less air occupying its empty space. petrol evaporates faster than you can imagine. Petroleum storage tanks have an internal floating roof.  This roof serves as zero clearance between the petrol and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every litre is actually the exact amount.
Another reminder, if there is a fuel truck pumping into the storage tanks when you stop to buy, DO NOT fill up--most likely the petrol/diesel  is being stirred up as the fuel is being delivered, and you might pick up some of the dirt that normally settles on the bottom.
Hope this will help you get the most value for your money".
DO SHARE THESE TIPS WITH OTHERS! "
Now ! Interestingly I filled up the car this morning, from 2/3 full expecting it to come to about £18.00...it was full at £16.00.  using the pump trigger on a quarter to half "throttle" . More interestingly the auto cut off didn't kick in...perhaps because there wasn't all the vapour abd guggling involved with a "full throttle" fill up.
FRE07962128
Re: VERY Important Fuel Tips.
« Reply #1 on: 12 June 2008, 23:27:57 »
Thanks for those great tips Duggs! :y :y
It is amazing what you know when 'in the trade' ;D ;)
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #2 on: 12 June 2008, 23:29:37 »
Ah, right thats a old message, based in the US from circa 1999 to 2007
http://www.snopes.com/inboxer/household/gastips.asp
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 12 June 2008, 23:33:51 »
Cheers for that I will give it ago :y
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 12 June 2008, 23:36:10 »
Blimey...NOT only is it old but almost the same...word for word with a few strategic alterations...
Still..its worth knowing...which I didn't...until now.
« Reply #5 on: 12 June 2008, 23:38:48 »
Either way, very interesting information.
I noticed filling up a few times the auto cut off kept kicking in and now, thinking back, it was allways on warm, hot days.   :y :y
« Reply #6 on: 12 June 2008, 23:41:36 »
Now then, i wondered while reading the part about filling when half full that any gain would be lost by driving around with the waight of a permanently full tank. :-? but 2 quid ceaper for 1/3 of a tank?????
   i like the sound of filling early a.m. my shift starts 6 am! :y
Thankyou kindly. ;)
« Reply #7 on: 12 June 2008, 23:42:42 »
Sorry .. I disagree with most of this ...
Fuel storage tanks are well below the ground .. often 10-15 feet to the TOP of the tank, let alone the bottom... at these depths the temperature is virtually constant throughout the year .. let alone changing overnight !!!
Vapour is caused by the latent heat of evaporation, not by fast filling/stirring etc etc ...  .. in order to evaporate fuel absorbs heat from the atmosphere ... so it could be argued the faster you fill then seal your tank with the filler cap the less you lose .. but it is probably less than 1/10 a teaspoon full difference !!
Modern fuel tanks are vapour sealed to prevent polution .. thats why the fuel injector system has a return to the tank, and you get a "shush" noise when you open the tank .. so no fuel vapour can escape from a sealed system ...
The tank pickup is some way off the bottom just for this reason, and the pumps have filters fitted as well ...
The autocut of is activated by pressure .. vapour cannot produce pressure in an "open" system .. it is liquid that operates it ... if you pump slowly you get less "splash back" so fewer "cutoffs"
To fill a tank takes a specific volume of liquid .. the difference between £16 and £18 is over a litre  .. do you really think a few little tricks like this can save you THAT much fuel ?? .... IMHO you simply overestimated how much you needed ..
Just my opinion BTW ...   :)
« Last Edit: 12 June 2008, 23:44:18 by entwood »
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #8 on: 12 June 2008, 23:44:28 »
Modern fuel tanks are vapour sealed to prevent polution .. thats why the fule injector system has a return to the tank, and you get a "shush" noise when you open the tank .. so no fuel vapour can escape from a sealed system ...
Agreed TBH
« Reply #9 on: 12 June 2008, 23:49:52 »
In that case then it would be interetsting to see the Top Gear test rerun with the V8 Audi to Scotland and back from London on a hot sunny day starting with an empty tank at 2pm and see what the difference is.
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #10 on: 12 June 2008, 23:52:23 »
Dont forget the air density on a hot day is less and will effect the running of the motor, much like driving at high alitudes.
« Reply #11 on: 12 June 2008, 23:56:03 »
Air density will probably affect performance, and thus fuel usage, far more than the items above ... as will hot days when folks either run aircon harder, or open windows/sunroofs and increase the drag co-efficient substantially !!
Best (most efficient) operation will always be mid-winter .. :)
(actually a cold, dry day, in the bottom of a deep valley is best .. :) as you get the highest air pressure then .. :) )
« Last Edit: 12 June 2008, 23:58:31 by entwood »
rad cap
  • manchester
« Reply #12 on: 13 June 2008, 00:02:29 »
have heard similar things in the past, interesting stuff, but lets get the price of fuel down , we just keep getting ripped off :-X
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #13 on: 13 June 2008, 00:06:04 »
However !  I've yet to come across a motorist who doesn't think that the first half of a full tank goes down slower than the bottom half.
I've driven a variety of vehicles over these past 27  years or so and in every case, the first half lasts longer in terms of milege than the last half. Why is that prey tell ?
« Reply #14 on: 13 June 2008, 00:06:23 »
Thames valley ok? commute Reading to Slough. ;D
Pages: [1] 2 3  All   Go Up
