Author Topic: Oil cooler plate question  (Read 3778 times)
Ironingboard
  • Edinburgh
« on: 06 June 2008, 01:22:11 »
Can the oil cooler plate be resealed without removing the oil cooler or pipes?
I have a coolant leak around the edge of my oil cooler, I'm wondering if it can be lifted up enough to reseal it or could I run sealant along the outer edge of the plate to reseal it?
Any insights or knowledge would be appreciated  :y
« Last Edit: 06 June 2008, 01:23:20 by Ironingboard »
GPar
  • Chatham, Kent
Re: Oil cooler plate question
« Reply #1 on: 06 June 2008, 01:57:56 »
You could reseal the cover but only by disconnecting pipes, removing it and lifting out the oil cooler to clean up everything especially the mating surfaces. You would also need new 'o' rings for between the top of the two inlet/outlet pipes and the cover. Doubt you will seal the leak for any length of time without doing this. If when you take it apart you have the old pre-stainless cooler I'd renew that anyway. Maybe facelift versions have stainless coolers, mine is pre facelift.
Geoff
« Last Edit: 06 June 2008, 02:00:14 by GPar »
« Reply #2 on: 06 June 2008, 08:44:16 »
You need to pop it out to re-seal it.
And they all had stainless coolers from about 95 onwards
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 06 June 2008, 09:06:21 »
But still keep failing >:(
« Reply #4 on: 06 June 2008, 09:12:42 »
When badly maintained.............
Dazzler
« Reply #5 on: 06 June 2008, 09:17:44 »
I ad one fail on a Vectra 2.6 with only 38k on the clock and the antifreeze had been replaced.
I asked Vx parts man about it and he said the oil coolers are crap in there construction :-?
« Reply #6 on: 06 June 2008, 09:21:18 »
And what would a parts man know about thier construction.......
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 06 June 2008, 09:31:24 »
When the cylinder heads are fitted there is not enough room to lift the heat exchanger straight out. The process is:
Plennum, intake bridge and inlet manifold off
Coolant bridge off
Loosen oil pipes at oil filter end (Need crows foot spanners)
Disconnect oil pipes from heat exchanger and lift up as far as poss.
Undo nuts fixing heat exchanger to cover plate
Unbolt cover plate from block.
Lift off cover plate
lift out heat exchanger.
You have to clean and degrease (cellulose thinners etc) the block face and cover to get the sealant to stick properly.
New O rings on the heat exchanger and place in block.
Apply sealant to cover and fit, tighten the bolts evenly.
Refit nuts to heat exchanger and tighten.
Bits:
Heat exchanger O rings x2
Grey sealant
oil pipe washers x4
coolant bridge Dowty washers x4
You may find that the heat exchanger nuts strip the threads when removing. If this happens then get a replacement kit (part numbers in maintenance section).
Ironingboard
  • Edinburgh
« Reply #8 on: 06 June 2008, 10:44:14 »
Cheers thanks for the info, what size of crow foot spanners do I need?
« Reply #9 on: 06 June 2008, 10:45:59 »
19mm crows foot! :y
Ironingboard
  • Edinburgh
« Reply #10 on: 06 June 2008, 10:49:30 »
19mm crows foot! :y
Just the one? great at least I won't have to buy a whole set of tools I'm never gonna use again  ::)
« Reply #11 on: 06 June 2008, 10:58:32 »
Stainless mounted on an aluminium cover is a bit of a liability with respect to galvanic action, so it's even more important to ensure the coolant's corrosion inhibiting properties are intact, although I'd expect the cover to suffer rather than the cooler.
http://en.wikipedia.org/wiki/Galvanic_series
GPar
  • Chatham, Kent
« Reply #12 on: 06 June 2008, 12:26:33 »
Well the one I just took out of my '99 V6 was def ally and looked nothing like the new shiny stainless one! Perhaps an old one off the shelf put in before I had the car?
Geoff
Ironingboard
  • Edinburgh
« Reply #13 on: 15 June 2008, 18:00:53 »
OK I think I might be able to reseal my oil cooler plate without having to buy a new oil cooler and cover plate.
I seen this on ebay, does that mean I can remove the oil cooler with the plate still attached and reseal it without removing the cooler from the plate?
http://cgi.ebay.co.uk/VAUXHALL-OPEL-OMEGA-V6-ENGINE-OIL-COOLER_W0QQitemZ380036975036QQihZ025QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Is there enough space to do this?
Can this be done without draining the oil from the engine?
« Reply #14 on: 15 June 2008, 18:31:41 »
Antifreeze changed at the ludicrous 5yr interval no doubt....
