Author Topic: Removal of headlamp covers  (Read 3772 times)
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« on: 16 June 2008, 13:39:50 »
Could anybody point me as to how to remove the headlamp covers, as they are quite yellow and dirty looking. I did have a look this morning, but though I would ask first.  :y
Re: Removal of headlamp covers
« Reply #1 on: 16 June 2008, 16:34:02 »
Many prefacelifts get like this
The best cure - an upgrade to some projector lights :y
psychnurse
« Reply #2 on: 16 June 2008, 16:56:39 »
That could be on the cards as a long term project! Just looks nicotine stained-yuk
« Reply #3 on: 16 June 2008, 16:59:54 »
It is possible, with care, to "refurbish" the lenses a little ... use 1500 wet/dry followed by T-cut, this can remove a lot of the scale/traffic film that causes the discolouration.
Needs to be done carefully or the metalwork surrounding the lights gets a serious and messy hit .. :(
Does work, takes time and effort though  :(
« Reply #4 on: 16 June 2008, 16:59:58 »
Estate is the same, they ALL get like that
Try T-cut on them with some fine wet and dry paper - it can help
psychnurse
« Reply #5 on: 16 June 2008, 17:04:19 »
Is it on the outside??? I thought it was build up from the inside.
« Reply #6 on: 16 June 2008, 17:08:35 »
Bit of both !
psychnurse
« Reply #7 on: 16 June 2008, 17:15:56 »
Will have a look just now. Thanks for that  :y how do I get inside, is it easy?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #8 on: 16 June 2008, 17:21:59 »
No it's not!!! ;D
« Reply #9 on: 16 June 2008, 17:22:58 »
honest answer is - I've never done it!
psychnurse
« Reply #10 on: 16 June 2008, 17:28:03 »
o well, will stick to the outside for now and see if that improves the opacity. If not then I may have a look at getting it.  :y
lcdman
  • Leeds, God's county
« Reply #11 on: 16 June 2008, 19:03:26 »
I've just changed both my headlights for this exact reason! I had a go at dismantling one of those I removed to see if the front would come off (for curiosity's sake you understand)
FORGET IT.  ;D
It is held on to the rear case with some clips around the edge, but also some of the strongest sealant/goo I've come across - certainly keeps the water out.  Totally cracked the first one I tried and didn't even try the other.
Do what I did and replace the entire unit (with 2nd hand ones that aren't in such bad nick) - it is a 15 minute job per side tops!  Grill off (2 screws), trim strip off (1 screw each side), headlight assembly out (3 screws/bolts) unplug 3 plugs, reverse procedure.
psychnurse
« Reply #12 on: 16 June 2008, 19:09:58 »
FORGET IT.  ;D
Thanks for that mate.  :y :y
bruce
  • HEMEL HEMPSTEAD HERTFORDSHIRE
« Reply #13 on: 16 June 2008, 22:22:40 »
The lens can be taken off fairly easy..you need a hot air gun, I used the wife's air drier played around the lens edge where the black glue is..and made one good HID headlight from two F***ed up ones.
Bruce
« Last Edit: 16 June 2008, 22:27:19 by bruce »
« Reply #14 on: 16 June 2008, 22:31:11 »
If they are too bad they can fail the MOT our old estate did, got two replacement lights of ebay...easy to replace. :)
