Author Topic: Oil Level Warning on Display  (Read 1398 times)
nen3906
  • Tamworth
« on: 17 June 2008, 08:08:31 »
Hi there
        I have a 2.5 Elite Estate on a R plate, covered 150k.  The car has a full service history.  I check my oil weekly and it never loses any.  Recently whilst travelling on the motorway travelling @ 65ish, the 'Check Oil Level' warning came on the display.  It stays on for approx 5 miles then goes off.
  Would this be an oil pump problem, or oil pressure switch, or something completley different.
Thanks in advance.
« Last Edit: 17 June 2008, 09:01:32 by nen3906 »
Re: Oil Level Warning on Display
« Reply #1 on: 17 June 2008, 09:11:41 »
Hi there
Thanks in advance.
There's a level switch in the base of the steel sump. That would be my first check. When I replaced my sump pan, the wiring to this switch was quite hard & one of my connections broke & had to be re-soldered before I put it back. You could have the same/similar problem.
nen3906
  • Tamworth
« Reply #2 on: 17 June 2008, 10:54:33 »
Thanks, ill have a look
Markjay
  • London
« Reply #3 on: 17 June 2008, 14:49:18 »
The oil level sensor is at the bottom of the sump, on the inside, as are the wires. So you can't see anything just by looking under the car....
It does sound as if the sensor is playing-up, though if you are happy that the oil level is correct I wouldn't worry about it, it is probably not worth taking the sump off just for this.
The only other worry is if the sensor isn't working properly because it is covered in muck due to infrequent oil changes in the past, in which case it might be worth taking off the sump and giving it a good clean on the inside....
« Last Edit: 17 June 2008, 14:50:38 by markjay »
Alas, no more Omegas....
