Author Topic: Decokeing the plenum?  (Read 3590 times)
VX1
  • Reading, Berkshire
« on: 06 June 2008, 22:53:27 »
Is there anyone in Reading that has removed the plenum on a V6 that might be able to help me this weekend as I want to decoke the plenum and throttle body of all the black deposit crap? Any help would be appreciated.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
Re: Decokeing the plenum?
« Reply #1 on: 06 June 2008, 23:41:04 »
lots of wynns carb cleaner :y
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« Reply #2 on: 07 June 2008, 05:38:58 »
It's absolutely straightforward. Just don't drop anything into the inlets while the plenum is off. Stuff each with kitchen roll. Don't forget to clean out the idle control valve as well and the pipes in the plastic case running over the top of the plenum. There is a 'how to' in the maintenance section somewhere
VX1
« Reply #3 on: 07 June 2008, 09:18:07 »
Got plenty of carb cleaner, so no worries there!
VX1
« Reply #4 on: 07 June 2008, 09:19:04 »
I know its straight forward but I was wondering if anyone wanted to give me a hand  ;) ;)
mike213735
« Reply #5 on: 07 June 2008, 09:25:46 »
I might be about tomorrow afternoon. 3pm ish if that helps?
Mike
VX1
« Reply #6 on: 07 June 2008, 09:26:51 »
yep thats good.
mike213735
« Reply #7 on: 07 June 2008, 21:18:49 »
OK mate,
See you at 3pm tomorrow.
Mike
VX1
« Reply #8 on: 08 June 2008, 19:47:48 »
I would like to thank Markjay for the how to on removing the plenum on a v6. Decided to take the plunge and do this myself. With the help of the instructions, which are very easy to follow, I managed to remove all the parts to enable me to remove the plenum. Once I had removed the plenum I then removed the throttle body to give it a proper clean. I had bought 10 cans of carb cleaner and used 6 on the throttle body and the plenum.
Throttle body came up trumps as for the plenum itself well I got some of it clean but not all but it will do. Whilst I was at it I also cleaned the black eco bit on top of the plenum as well and christ the black crap that came out of that so should be all nice and clean even unblocked the two small holes.
   Now the car sems to idle at the right speed (500 rpm) and seems to have no more hesitation when blipping the throttle.
So I would like to give a big thank you to Markjay, without the How To I would not have attempted to do this by myself.
[size=48]THANK YOU MARKJAY[/size] :-* :-*
Paul  :y
« Last Edit: 08 June 2008, 19:50:50 by vauxhallomega1 »
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #9 on: 08 June 2008, 22:03:35 »
Result  :y :y :y :y
less
  • Hemel Hempstead
    • 2.6 auto saloon
« Reply #10 on: 08 June 2008, 22:44:28 »
Nice one  :y
In fact, thanks to all of the guys who have taken the time to create the 'how to's - I feel much more confident with the guides.  :y :y :y
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #11 on: 09 June 2008, 09:41:31 »
you'll be surprised at how quick you can get the plenum off and on after a few times of doing it. just be careful with the bolts, it being aluminium and all...
PM with your requests.
stuart30
« Reply #12 on: 09 June 2008, 10:10:17 »
Thats a mighty fine looking car you have VX1..... :y
Hope she"s been trouble free for you. :)
bth2bth2
  • sunny blackpool
« Reply #13 on: 09 June 2008, 15:28:19 »
instead of buying cans of carb cleaner try a 5ltr tin of thinners.youll notice its pretty much the same stuff and a tad cheaper.
brian
VX1
« Reply #14 on: 09 June 2008, 20:13:17 »
Yep she has been trouble free for me stuart thanks. How's yours doing?
Paul  :y
