Author Topic: Black sealant used for thermostat question  (Read 1899 times)
Ironingboard
  • Edinburgh
« on: 17 June 2008, 17:42:35 »
Does anyone have any experience with using black sealant around the thermostat, does it break down or is it ok to use it?
I used it when I changed my thermostat and I've just resealed my oil cooler plate using the gray sealant, I'm wondering if I should take the thermostat out and reseal it with the gray stuff.
Any comments or experience would be appreciated.
This picture was taken before I resealed my oil cooler plate.
« Last Edit: 17 June 2008, 17:43:45 by Ironingboard »
Dazzler
  • Haverhill, Suffolk
Re: Black sealant used for thermostat question
« Reply #1 on: 17 June 2008, 17:50:50 »
If it was a new state and housing with a new o-ring, then it should be fine.
If you were just resealing it then i don't think the black will last that long.
« Reply #2 on: 17 June 2008, 17:51:06 »
Its the grey sealant for the thermostat as well :y
« Reply #3 on: 17 June 2008, 19:35:05 »
Grey sealent is more suited to the stat but, if its a new stat and seal then it should be fine anyway.
The black sealent works quite nicely on the stat threads.
Ironingboard
  • Edinburgh
« Reply #4 on: 17 June 2008, 20:21:51 »
Well it was annoying me that it might be leaking with the wrong sealant and opened the thermostat anyway.
I'm in the process of cleaning the old black sealant off and I found there's little of the black sealant left inside the thermostat.
The sealant that was left was very brittle which explains the small blobs of black rubbery stuff in my header tank and in various cooling pipes
So it looks like me and the bast**d bolt have got another run in tomorrow after we parted company destined never to be seen again  :y
« Reply #5 on: 17 June 2008, 20:55:26 »
As a tip, seal the vent hole on top of the power steering reservoir with some tape or a rubber glove.
Unbolt the reservoir and move it out the way (towards the battery), you can now get into the B-bolt easily and the power steering hose is also much less of a hinderance.
« Last Edit: 17 June 2008, 20:56:22 by Mark »
Ironingboard
  • Edinburgh
« Reply #6 on: 17 June 2008, 22:12:26 »
Thanks Marks, much appreciated, worked something like that out the hard way, except I push the power steering reservoir to the back.
I'll try your way mark and see what happens, no doubt I'll be on here later wondering how to change the power steering hose.
