Author Topic: ECU connections  (Read 1015 times)
ECU connections
« on: 20 June 2008, 11:46:55 »
Hi Guys
Please does anyone know which ECU connector pins are for the below, on a 1999 2.0 Manual?
RPM signal
Lambda Sensor
Thanks in advance
James
Martin_1962
Re: ECU connections
« Reply #1 on: 20 June 2008, 12:58:01 »
RPM is usually green
Do you have the Haynes manual?
Re: ECU connections
« Reply #2 on: 20 June 2008, 20:26:40 »
2.0, 2.5, and 3.0 are covered by Haynes manual.
Martin_1962
Re: ECU connections
« Reply #3 on: 20 June 2008, 21:15:41 »
RPM green pin 32
4 wires to Lambda
25 Black Yellow
7  Yellow
37 (heater)
46 (shared earth)
