Author Topic: Omega Mv6 Flywheel and clutch..HELP!!  (Read 831 times)
Nieminen
« on: 22 June 2008, 17:14:20 »
Hi.
What flywheel and cluth match X30XE engine?Car was Automatic transmissions and i put the manual transmission R25/28.
Im living in finland, here are not found orginal x30xe manual flywheels.
Thanx. Sorry my bad english  :-[
« Last Edit: 22 June 2008, 17:15:54 by Nieminen »
Re: Omega Mv6 Flywheel and clutch..HELP!!
« Reply #1 on: 22 June 2008, 21:24:45 »
Hmmmm. if you cant source the 3.0 one then you might be forced to plump for the smaller 2.5 version (although should not be to much of a problem)
Dont forget you will need the spiggot bearing in the end of the crank to!
