Author Topic: Throttle Housing  (Read 1111 times)
A380 Elite
  • Ashford, Middx.
Throttle Housing
« on: 24 October 2007, 08:56:30 »
Before i remove my throttle housing for cleaning.
I understand i also need to replace the sealing rings.
Looking on the forum, i need
Part no 904 675 43, one off and
Part no 905 009 83, four off.
Is one of the above the sealing rings and what's the other for?
Thank you in advance.  :y
Darth Loo-Knee, He The Man
Re: Throttle Housing
« Reply #1 on: 24 October 2007, 16:17:11 »
Ryan, I'll do it all for you when I come up. Cleaning the throttle body is no problem.
However if you do want to have a go yourself.... the seal is a soft rubber one, I never replace it..  :-X
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #2 on: 24 October 2007, 21:00:53 »
if you seperate the throttle body from the plenum you *may* want to change the sealing rings between the two - in which case you'll need 2 of P/N 90412566 ...
