Author Topic: Brake discs - where to buy?  (Read 3534 times)
TECHNOPUG
  • Islington - London & Essex
« on: 19 June 2008, 14:17:01 »
Just been quoted £100+VAT for a pair of front discs from the Stealers.
Any suggestions where I can get them at a sensible price - Halfords maybe? I'm pretty limited for time - need them buy Saturday.
Cheers,
Andrew
Re: Brake discs - where to buy?
« Reply #1 on: 19 June 2008, 14:22:16 »
£100 should easily get you the Disk and Pad Axle set on trade club ;)
May also need a wear sensor or 2.
Brake Disc & Pad Kit, Front
                                                               Retail         Trade       Tradeclub
All models exc. 2.0 to '97       93175466       £98.50       £81.31       £71.40
all plus vat
They are highly recommended over post pattern ones for noise, performance and longevity.
If you havent got a tradeclub card, where are you based, someone may be able to help you out  :y
« Last Edit: 19 June 2008, 14:23:46 by jimbob »
« Reply #2 on: 19 June 2008, 14:22:59 »
Disks and pads from stealers on a Trade Club Card.  Not sure where you live, maybe there is someone local.
You just missed a few sets on Fleabay of Genuine Disks and Pads @ £50
« Reply #3 on: 19 June 2008, 14:27:09 »
all plus vat
Lol
We posted at the same time. :y
carper
  • Yorkshire - Hecky
« Reply #4 on: 19 June 2008, 14:31:09 »
Cheers,
Andrew
Not sure where in the country you are  :question
I use Autovaux (Wakefield) ........
http://www.autovaux.co.uk/LoadPortal.aspx?cnum=23&tabid=5&vnum=141
TECHNOPUG
« Reply #5 on: 19 June 2008, 14:41:08 »
The car is in North Essex.
For some reason I just thought that they be a fair bit cheaper. Gonna push us over the magic £1k budget.
Will inspect the current ones first and providing that there is no uneven wear, will stick with them I think. Already bought some Fast Road pads for it - so will just put those on and chnage the brake fluid for a higher spec. Dealers quoted me almost £200 for OE dicsc and pads.....
....incidently, whilst I have your attention - what does the handbrake adjustment look like, where is it, is there one for each wheel and is it pretty straightforward and obvious once under the car? And finally, does it matter which order the brakes are bled on a '96 car?
Cheers,
Andrew
ians
  • Reading
« Reply #6 on: 19 June 2008, 17:48:46 »
There is a maintenance guide for the handbrake adjustment - a bit of a pain in my view.
Haynes contains the bleed sequence - not sure how critical it is.
TECHNOPUG
« Reply #7 on: 20 June 2008, 11:09:44 »
The handbrake works but you have to pull it righ to the top.
« Reply #8 on: 20 June 2008, 11:15:27 »
Do it right and it wont need doing very often  :y
Bleed sequence is not important just dont get any air in it!
« Reply #9 on: 20 June 2008, 11:18:15 »
I would tend to agree but, Haynes does give two sequences depending on year of car.
TECHNOPUG
« Reply #10 on: 20 June 2008, 11:20:04 »
Yeah, I was thinking that it's recommended on the later cars to bleed in a diagonal split?
TECHNOPUG
« Reply #11 on: 20 June 2008, 11:24:37 »
Hmm....it just says "now you can adjust the handbrake cable...."
Nevermind, I'm sure that I'll figure it out when I'm under the cars. I'm used to adjusting the cable at the handbrake end, rather than the barke end.
Martin_1962
« Reply #12 on: 20 June 2008, 12:56:11 »
I got mine from Autovaux
ians
  • Reading
« Reply #13 on: 20 June 2008, 13:06:53 »
basic proceedure is
- remove heatshields under car - Plusgas recommended to avoid shearing studs)
- slaken off under car (may already be slack with handbrake off)
- adjust at each rear wheel so the shoes are just off the drum
- tighten under car so lever comes on at an appropriate number of clicks
..strange I thought Marks guide covered this :-/
The problem I have never reaslly successfully dealt with is that setting the central adjuster such that it is just starting to bite at 3 clicks (ie notice some resistance when spinning the wheels), still means that I have to pull the handbrake up to my armpit to get it to hold the car on a hill.
I would welcome any enlightenment :y
TECHNOPUG
« Reply #14 on: 20 June 2008, 13:50:22 »
I thought that the guide was for changing the rear discs? Will have to read properly rather than skimming...
