Author Topic: Heater Blower Motor for 2.5 V6 W plate  (Read 1462 times)
Darren Green
  • Lancashire
« on: 23 June 2008, 17:02:02 »
The heater blower motor is on its way out so I went to a Vauxhall breakers and he said he needs to see, touch and vertually taste the motor to tell me if the replacement will fit.
Does anyone know if my Omega has a special type of heater blower or would one from another Vauxhall (Astra or something) be okay?
Mines a V6 2.5 CDX on a W plate.
Has anybody got a motor to sell as well please?
Thankyou,
Darren.
Re: Heater Blower Motor for 2.5 V6 W plate
« Reply #1 on: 23 June 2008, 17:21:56 »
Only one type of motor fitted......that I am aware of!
What are the symptoms for failure?
Darren Green
  • Lancashire
« Reply #2 on: 23 June 2008, 18:26:14 »
The bearings I think as the faster the setting the noisier it becomes, also, The passenger airbag vibrates.
Taxi_Driver
« Reply #3 on: 23 June 2008, 18:32:39 »
It will have lost a balance weight off one of the blades then........
Will keep going but as you say it will be noisey and vibrate.....
For my 2.2 there were two different types.......But i got lucky and one from a 2.0 fitted, the motors are the same i think, its the plastic surround that varies.
I'll try to find more info for you........
Darren Green
  • Lancashire
« Reply #4 on: 23 June 2008, 18:45:29 »
As I already have the existing housing then would either motor fit into it or is the motor compete with the housing?
Thanks for your help.
Taxi_Driver
« Reply #5 on: 23 June 2008, 18:48:46 »
-MOTOR, ASSY., FAN, RHD   -V1000558 90509619
-MOTOR, ASSY., FAN, RHD  V1000559- X1999999 90541103
Best I could come up with.........i carnt remember how i found out an early 2.0L one would fit mine.......the later 2.0 doesnt apparently.
As said before i think its the plastics that are different........however it may be possible to swap the plastics over  :y
