Author Topic: flushing marmite from 3.2  (Read 3473 times)
« on: 20 June 2008, 09:44:59 »
changed oil weekend, got car 3 weeks ago, last service was 14 moths before, and just started(twice) to get  a rattle from left bank on cold start up. Oil obviously not good and crusty flakes round filler neck(normal?) dislodged by funle probably. Local mek said to flush it, not keen from what i hear on here, but  he also mentioned to flush with diesel!!! Due to its detergent qualitys. Just want to stop the rattle myself as oil changed 6 days ago now and rattle still there, maybe slightly better.  Whats best thing? Cheers
Re: flushing marmite from 3.2
« Reply #1 on: 20 June 2008, 09:47:34 »
.....  Whats best thing? Cheers
Some more oil changes. :y Trade Club prices will give you an oil change for less than £15.
« Reply #2 on: 20 June 2008, 09:47:45 »
Short oil changes are the answer.
Heres the issue.
The trouble with a flush is that yes, it will clean a load of the deposits off but its not un-common for these to then block the oil pickup pipe!
Oil is a good cleaner......so that is the approach I find best.
« Reply #3 on: 20 June 2008, 12:32:52 »
 thanks guys will do:y
Your not shocked by the diesel idea then. Not doing it on my car,what ever.
dippydave
  • Sutton Coldfield, West Mids
  • how personal?
    • Vectra 2.0DTi Elite
« Reply #4 on: 20 June 2008, 12:43:10 »
Just as a matter of interest, where's the oil pickup pipe?
And if it were blocked, would it cause extra pressure in the oilways, and maybe force oil out through the camcover gaskets?
Vectra Elite Estate doing good post-Omega service but still not as nice to sit in.
One last Omega on the drive, one Corsa on the lawn...maybe they'll go to a good home before too long!
« Reply #5 on: 20 June 2008, 12:45:16 »
I won't tell you what we did with a Rover 214 and a couple of gallons of diesel ::)
ians
  • Reading
« Reply #6 on: 20 June 2008, 12:55:58 »
In the sump I presume.  I would have thought it would lead to low oil pressure.
Martin_1962
« Reply #7 on: 20 June 2008, 12:57:12 »
Is it worth dropping the sump and checking the pickup tube?
ians
  • Reading
« Reply #8 on: 20 June 2008, 13:14:56 »
I think I would go for the regular oil changes for a bit and see if it improves.
Would 3.2's be of a generation where service was every 20k miles?
« Reply #9 on: 20 June 2008, 13:19:26 »
You sure he didn't suggest using an engine oil designed for diesel cars? These do have stronger detergent additives. A little diesel in the oil would probably act as a solvent, so the same as flushing really.
However, it all comes down the whether you shift the dirt all in one go, and potentially clog the pickup, or gradually over the course of a few oil changes.
dippydave
  • how personal?
« Reply #10 on: 20 June 2008, 13:33:09 »
even despite the high cost of a barrel of oil the price of engine oil still seems bargainous. i'd definitely go that route to clean the engine. Mine's had three changes in 12 months!.....and that's only about 5000 miles! (lots of short-journey mayo and an oil cooler change!)
« Reply #11 on: 20 June 2008, 13:47:36 »
Nope, he ment drop the oil, re fit sump bolt. Replace oil with "DIESEL" to the top of dipstick and "RUN THE ENGINE" on tick over only for 30 mins!!! He talked about proper flush treatment, but said in extreme cases use diesel. "Use what" i said. It has highest level of detergent in it, was the thinking behind it. Maybe as a last resort, that or scrap it, but i not doing it. Oh No!
« Reply #12 on: 20 June 2008, 13:57:34 »
Yes high levels of detergent and low levels of lubrication properties.......what an idiot.....note, never buy a car off him!
« Last Edit: 20 June 2008, 13:58:05 by Mark »
« Reply #13 on: 20 June 2008, 14:03:13 »
Umm. :o No, thanks. That's about as good as running it with no oil.
Stick to a few regular oil changes.  :y
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #14 on: 20 June 2008, 17:55:12 »
Now you said that bet it goes up in price pretty soon LOL !
I still have a 5Ltr of CastrolGTX oil in garage never did change my 2.0CD over to semi synth  price on it £7.99 LOL  so one more oil change of std oil then will go the Synth route ! :y
