Author Topic: Rear diffs?  (Read 3972 times)
DaveMarshall
  • Swindon/Cirencester
Rear diffs?
« on: 24 June 2008, 20:45:59 »
Are facelift rear diffs different on different models?  I have a customer possibly after a rear diff for his 2.2 16V petrol manual and I have a diff for a 2.6 petrol auto does anyone know if they are the same?
Thanks, Dave.
[SIZE=20]Vauxhall's breaking and wanted for breaking
E-Mail me at southwestvauxhallspares@yahoo.co.uk[/SIZE]
Re: Rear diffs?
« Reply #1 on: 24 June 2008, 20:47:52 »
there will be a difference between manual and autos i think
LSD is very rare.
« Last Edit: 24 June 2008, 20:48:55 by tunnie »
DC
  • Switzerland
Re: Rear diffs?
« Reply #2 on: 24 June 2008, 21:12:15 »
LSD is very rare.
not too rare in switzerland. I've got one on a 2.5V6  :y
DC
  • Switzerland
Re: Rear diffs?
« Reply #3 on: 24 June 2008, 21:13:48 »
LSD is very rare.
not too rare in switzerland. I've got one on a 2.5V6    :)
i hope this is better
Re: Rear diffs?
« Reply #4 on: 24 June 2008, 21:16:39 »
I've got one too ;)
DaveMarshall
Re: Rear diffs?
« Reply #5 on: 24 June 2008, 21:41:09 »
So have we decided if manual and auto diffs are the same or different lol  Might have a sale if they are the same.
Dave.
Re: Rear diffs?
« Reply #6 on: 24 June 2008, 21:43:44 »
according to haynes book of 'dangle berries',they have different ratios :y
Re: Rear diffs?
« Reply #7 on: 24 June 2008, 21:51:19 »
I'm no hot-shot with the EPC but AFAICT :
The EPC lists 4 diffs for the 2.2 and 6 for the 2.6, but doesn't stste if manual or auto .. just uses the ident labels... FU,GR,FG, GP  the addition 2.6 ones are DX, GM .. the part numbers for the FU's etc are the same ....
so some "could" be the same, but if, for example and I don't know if this is how it works ... F= manual and G = auto then the part numbers are different
not a lot of help is it
« Last Edit: 24 June 2008, 21:52:42 by entwood »
DaveMarshall
Re: Rear diffs?
« Reply #8 on: 24 June 2008, 21:55:05 »
Thanks for that   :y  Bit of a tricky one really.
Dave.
Re: Rear diffs?
« Reply #9 on: 25 June 2008, 10:01:20 »
There's a bit of info on this thread http://www.omegaowners.com/forum/YaBB.pl?num=1214205190.
It implies that the 2.0 manual and 2.5 outo had the same diff ratio (3.9). So, it may well be the case that 2.2 manual and 2.6 auto were also the same. Either way, it's an indication that the two setups are closely matched and that, even if the ratio is not the same, it'll be close.
I'm sure it would work, but you might risk having a slightly different ratio at the end of it. If you're still concerned I guess try and see if you can find any markings on the two diffs - or rotate the input shaft and count the turns for 10 revolutions of the output shafts, then divide by 10 to get the ratio.
Re: Rear diffs?
« Reply #10 on: 25 June 2008, 11:07:50 »
2.2 are as follows:
Auto 4.22
Manual 3.9
2.6
Auto 4.22
Manual 3.9
So, as you can see, they are the different
« Last Edit: 25 June 2008, 11:09:14 by Mark »
DaveMarshall
Re: Rear diffs?
« Reply #11 on: 25 June 2008, 19:51:39 »
Thanks for that i'll let him know that they are different.  What would happen if he were to fit the 2.6 Auto diff to his 2.2 manual would it work or would it all end in trouble lol?
Thanks, Dave.
Re: Rear diffs?
« Reply #12 on: 25 June 2008, 23:19:20 »
Thanks, Dave.
He would just see slightly higher engine RPM at a given speed. Might even improve acceleration as it'd be lower geared. Fuel economy might suffer a  little I guess. It wouldn't cause any major problems though.
I recall talk of the 4 pots having a different propshaft flange so you might need to swap the flange on the diff input shaft.
mkaminski100
  • Basingstoke
Re: Rear diffs?
« Reply #13 on: 26 June 2008, 12:06:02 »
2.2 has a higher ratio, but any diff should fit. If you will use one from 2.6 car will have higher max speed, but will accelerate slower.
DaveMarshall
Re: Rear diffs?
« Reply #14 on: 26 June 2008, 19:52:59 »
Thanks for all the help i'll let him know.
Dave.
