Author Topic: 2.0 dti wont start  (Read 1436 times)
gdti
2.0 dti wont start
« on: 25 June 2008, 15:33:04 »
w reg opel 2.0dti cut out wont  start  check derv up to injector pump ok,does not squirt to injectors any ideas.  thanks gary:'(
Re: 2.0 dti wont start
« Reply #1 on: 25 June 2008, 16:12:11 »
Codes read would be the ideal staring point but, likely to be crank sensor.
gdti
« Reply #2 on: 25 June 2008, 16:27:05 »
sorry no warning light or any indentification ,warning light comes on when injector pump unpluged
thanks gdti :y
« Reply #3 on: 25 June 2008, 16:48:53 »
thanks gdti :y
Should still store it as a fault or at least live data would give an indication.
Unlike a 'missing' injector pump (i.e. when its unplugged) a crank sensor with poor signal will still possibly show the correct static values but no position signal will get through.
I assume the ecu light is not flashing indicating an immobiliser fault?
gdti
« Reply #4 on: 27 June 2008, 08:52:58 »
yes no ecu light, ihave 2 of these car cars black 2.0 dti estate 169,000
and a03 2.2dti elite both have only broken down when the crank end pully fell apart.i think some thing has gone in the injector pump or could the ecu stop it with out a fault light.
 :yregards gary
« Reply #5 on: 27 June 2008, 09:00:57 »
 :yregards gary
Consider this scenario......the engine is cranking and no crank signal is being seen (althought the static DC values still check out and hence no light on).........the ECU wont let the pump fire.
Hence why it needs the codes reading and the live data checking
