Author Topic: fault code reader/camlock 2.2 1999 facelift  (Read 1002 times)
eddie c
  • richmond north yorkshire
    • 2.2dti 2001
« on: 26 June 2008, 19:51:37 »
hi everybody. can anyone recommend a cheap fault code reader 2.2 petrol and does it need a cam lock kit to change cambelt it looks easier than the v6 are these engines any good thankyou.
Pete Wright
  • Folkestone Kent
Re: fault code reader/camlock 2.2 1999 facelift
« Reply #1 on: 29 June 2008, 01:35:39 »
Hi
Yes you need a camlock tool. Draper and sealey do one for about £5.00 so not worth trying without one.
prev, Cav SR, 2 Astra 3's, Nova Antibes, 3 Carltons, 2 Omegas, 2 Vectras, 3 Cavalier 3's, Frontera Sport, 3 Rover 800s, 2 Ford Kas, 2 Rover sd1's, Rover P6, Discovery V8.
« Reply #2 on: 29 June 2008, 10:17:54 »
try this, works on my auto 3.2, but only works on some cars,(fill in your profile, we can tell what car you have then) you may be lucky. Get in and press brake and gas pedal to the floor then turn on ignition fully WITHOUT firing the engine. On my the car symbol with a spanner through it will flash out the codes for you..
Post on here and someone will know.
 Good luck
« Reply #3 on: 29 June 2008, 10:23:47 »
try this, works on my auto 3.2, but only works on some cars,(fill in your profile, we can tell what car you have then) you may be lucky. Get in and press brake and gas pedal to the floor then turn on ignition fully WITHOUT firing the engine. On myn the car symbol with a spanner through it will flash out the codes for you..
 Good luck
