Author Topic: autobox code 0700  (Read 1509 times)
batista
  • yardley wood birmingham
autobox code 0700
« on: 28 June 2008, 19:30:04 »
eml stays lit all the time.car keeps going into limp mode,so took it to garage today and they said that theres a problem with the autobox ecu,it keeps coming up code 0700.he said that theres no power going to the ecu ,does anyone know why this can be.all answers much appreciated :y
    • 530D M Sport, 330i Coupe
Re: autobox code 0700
« Reply #1 on: 28 June 2008, 19:54:28 »
Code 0700 is basically a Transmisson module failure code, however I would have expected to see other codes as well.  :-/
The module is accessable by removing the kick trim above the pedals and is mounted on the right so might be worth checking the multi plug is fully connected.
batista
« Reply #2 on: 28 June 2008, 20:03:26 »
cheers i will have a look at that.. :y
« Reply #3 on: 29 June 2008, 21:05:58 »
Also, check for codes in engine.  0700 and 1700 in autobox are often caused by engine saying to gearbox that its using reduced power (limp)
