Author Topic: curious code 135 telltale (checklight) voltage low  (Read 2037 times)
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« on: 01 July 2008, 23:19:09 »
code 135 telltale (checklight) voltage low.  I was wondering if this code has something to do with the little check message that appears in the bottom right of the computer display in the dash.  My check appears until I press the brake pedal or take the handbrake off.  Everything is ok on the car has I have had it serviced and checked.  Just wondering if anybody else has this or is it just one of those things.  Had code 19 which has since gone but now this one has appeared.  The check message has always been like it is since I bought the car but the code never showed up  in the paperclip test until now.  not worried just curious as to what it means :)
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
Re: curious code 135 telltale (checklight) voltage low
« Reply #1 on: 02 July 2008, 08:22:13 »
I had a load of codes like that after I removed my dash, and had the ignition on with it not reinserted properly, once cleared they did not return.
May be a similar issue.
« Reply #2 on: 02 July 2008, 20:24:34 »
135 is a code that does not seem to disappear on its own.
The CHECK light after starting but before pressing brake just means it hasn't tested brake light bulbs yet - I'm assuming yours is pre 1998, as later cars have a different msg on display
addy
  • County Durham.  UK
« Reply #3 on: 02 July 2008, 22:54:20 »
Hi TheBoy
Yes mine is a 1995 cdx auto, as you correctly say the Check light goes out after pressing the brake.
I was curious as to what it is refering to and how to remove this error code as it has only just appeared.  Could it be down to the fact that I disconnected the battery while sorting out the crank sensor?
As I said everything is working ok.
Thanks Adrian
« Reply #4 on: 03 July 2008, 08:32:28 »
Hi TheBoy
Thanks Adrian
You mean the 135 has just appeared? The usual causes for that are that someone has at some point removed eml to hide a problem, or switch ign on with dash out. But if its just appeared, I don't know.
The fact the EML works suggests nothing to worry about :)
addy
  • County Durham.  UK
« Reply #5 on: 03 July 2008, 09:12:16 »
When the crank sensor went the eml never came on. The bulb is working as I did the paperclip test and it flashed the code as I said.
Will keep trying the paperclip test and see if it vanishes.
Thanks anyway
« Reply #6 on: 03 July 2008, 09:14:12 »
Thanks anyway
19 rarely gives eml
