Author Topic: alloys et40  (Read 4059 times)
craig
  • north wales/connah's quay
alloys et40
« on: 03 July 2008, 13:58:39 »
would et 40 offset off a honda accord fit on my omega v6 99 please??? ::)
Re: alloys et40
« Reply #1 on: 03 July 2008, 14:02:44 »
Seem to recall that is too much.  Also, is PCD the same?
I'm sure one of the members more interested in wheels will be along with exact specs soon...
craig
Re: alloys et40
« Reply #2 on: 03 July 2008, 14:06:45 »
cheers :y do you think black 18"will look good on silver v6??
Re: alloys et40
« Reply #3 on: 03 July 2008, 14:07:53 »
sorry, I don't get excited about wheels. I leave that for the Corsa boyz  :P
craig
Re: alloys et40
« Reply #4 on: 03 July 2008, 15:22:11 »
just looked at mine and they say et38 so guess not???
markey mark
  • SLady bitshorpe north lincs
Re: alloys et40
« Reply #5 on: 03 July 2008, 15:28:15 »
iirc its et35 to et45 should fit no problems its the centre bore that causes problems ! :y
craig
Re: alloys et40
« Reply #6 on: 03 July 2008, 15:37:03 »
any idea how i can find this out please?? ::)
markey mark
Re: alloys et40
« Reply #7 on: 03 July 2008, 15:39:49 »
i sure its om here somewere fella ! or just go to an alloy wheel website they should have all the info  :y
craig
Re: alloys et40
« Reply #8 on: 03 July 2008, 15:41:28 »
cheers  :y will do!!
craig
Re: alloys et40
« Reply #9 on: 03 July 2008, 15:46:07 »
omega 65.1bore accord 64.1 so are they too small then???? :-/
markey mark
Re: alloys et40
« Reply #10 on: 03 July 2008, 15:49:56 »
ahh now the interesting part ! you can get spigot rings to take up the difference i presume its after market alloys your after ?? if so shouldnt be a problem fella when you order them tell them the bore size and they should sullply the correct spigot rings to fit yours !! :y
vrba
  • Croatia
Re: alloys et40
« Reply #11 on: 03 July 2008, 16:15:03 »
does this apply even if the bore on rim is smaller, i think that you can do that just in case if the bore is larger than original
Olympia5776
  • Ireland
Re: alloys et40
« Reply #12 on: 03 July 2008, 20:39:55 »
Erm...I think your missing something here lads.
The Honda is 5 X 114.3 mm PCD whereas the Omega is 5 X 110 PCD
Won't fit .
Don
vrba
  • Croatia
Re: alloys et40
« Reply #13 on: 04 July 2008, 10:21:05 »
omega is pain in the ass for getting rims. i want new rims cause mine  are little bumped up but i can't find any cause few cars has the same rims as omega
craig
Re: alloys et40
« Reply #14 on: 04 July 2008, 13:56:15 »
might me buying zafira gsi wheels :-/is there any pictures with these wheels on an omega???
