Author Topic: Cleaning breathers (symptoms)  (Read 1958 times)
willyboy
  • Leeds. West Yorks
  • Can Do !!
« on: 04 July 2008, 22:15:37 »
Always reading about cleaning the "breathers" cant imagine mine will have been done in last 10k,
 Whats the symptoms to look for if they possibly do need cleaning ?
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Cleaning breathers (symptoms)
« Reply #1 on: 04 July 2008, 23:09:48 »
Leaking rocker cover gaskets and oil in the plug wells  :y
Trade club card holder
Code scanner available
Pete Elite
  • Uxbridge, Middlesex
« Reply #2 on: 05 July 2008, 00:08:22 »
Hi willyboy,
               If you don't have any apparent symptoms then it would be best to give them a clean out now before you do! have some costly symptoms ;).
  They reckon on at least every year or average yearly mileage which is just about what 10k is :y.
« Reply #3 on: 05 July 2008, 12:43:02 »
oil in plug wells will prob go un noticed until the car starts miss firing as the ht leads fail due to heat oil and the spark escaping. seen mention of stressing the dis pac as well, a pig of a job to change and 200 sobs, ht leads not easy either 90 a side from dealer  :o 35 a set from euro car parts but the lengths are not exactly right on those. :-/
i would be getting them done asap, personally, and cheack all plug wells for oil. :y
amba
  • Medway towns
    • German V6
« Reply #4 on: 05 July 2008, 12:57:10 »
Famous saying "prevention is better than cure".If in doubt I would suggest you clean them as per the guide..you run the very real risk of expensive and much more difficult repair work as a result of not doing it.Oil and filter should also be replaced on a regular basis as it is the crap that the oil picks up,and when the oil starts to degrade, which causes the breathers to become blocked.Its then a certainty of future issues.
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #5 on: 05 July 2008, 15:29:11 »
Thanks guys will get on it asap (when weather improves as its an outside job for me I'm afraid)
Its typical weekend weather here peeing it down every 30 mins :(
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #6 on: 05 July 2008, 15:38:20 »
get yourself a few cans of wynns carb cleaner before you start, that will help clear out all the clag from your plenum and breather pipes and make your life quite a bit easier
PM with your requests.
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #7 on: 05 July 2008, 18:13:47 »
I take this is the guide  as have to admit not done it before but looks straight forward enough, looks like I need some new gaskets first though too
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #8 on: 05 July 2008, 19:36:39 »
Just take your time, follow the guide, and don't rush the job :y
I like red cars
