Author Topic: Autobox fault code 56  (Read 1129 times)
mkaminski100
  • Basingstoke
« on: 08 July 2008, 07:53:11 »
Can anyone tell me what a 56 autobox fault code is? I cannot find 2 digit autobox fault codes in internet.
This is not for me (my are 4 digit), it's for a friend's Omega TD.
Re: Autobox fault code 56
« Reply #1 on: 08 July 2008, 09:54:35 »
Here is a full list of the early codes for you:
00010      EEPROM not programmed
00013      Converter clutch solenoid valve - circuit interrupted
00014      Pressure regulator solenoid valve - circuit interrupted
00015      1-2/3-4 shift - circuit interrupted solenoid valve
00016      2-3 shift solenoid valve - circuit interrupted
00017      1-2/3-4 shift - short circuit to ground solenoid valve
00018      2-3 shift solenoid valve - short circuit to ground
00025      1-2/3-4 shift - short circuit to battery solenoid valve
00028      2-3 shift solenoid valve - short circuit to battery voltage
00029      Converter clutch solenoid valve - short circuit to ground
00031      Transmission output speed signal - Not present, short to ground or no voltage
00032      Pressure regulator solenoid valve - short circuit to ground
00033      Pressure regulator solenoid valve - short circuit to battery voltage
00034      Brake band solenoid valve - short circuit to battery voltage
00035      Brake band solenoid valve - short circuit to ground
00036      Converter clutch solenoid vale - short circuit to battery voltage
00039      Transmission output speed - incorrect signal (vehicle speed = 0)
00041      Transmission fault - Vehicle speed is to high relative to actual gear
00044      Braje band solenoid valve - circuit interrupted
00045      Permanent voltage - circuit interrupted
00048      Battery voltage low - (less tahn 9V)
00049      Battery voltage high - (greater than 16V)
00051      Control unit fail - EPROM defective
00055      Control unit fail - EPROM check sum fault
00056      Selector lever position switch - Function, adjustment
00057      Load signal from diesel electronics - Position of accelerator pedal (cruise control)
00058      ETR signal - (Engine Torque Reduction stage)
00059      Park/neutral output to control unit - Short circuit to ground
00060      Supply solenoid valves - circuit interrupted
00061      Monitor relay, current supply for - Short circuit to battery voltage solenoid valves in TCM
00062      Monitor relay, current supply for - Short circuit to ground voltage solenoid valves in TCM
00063      Monitor relay, current supply for - Circuit interrupted solenoid valves in TCM
00064      Monitor relay, current supply for - Watch dog defective solenoid valves in TCM
00065      Transmission fluid temperature sensor - short circuit to bat voltage
00066      Transmission fluid temperature sensor voltage low - short circuit to ground
00068      Transmission fluid temperature sensor - Temperature above 130degC
00069      Information output via P/N - Short circuit to battery voltage
00071      TV load signal - circuit interrupted or short circuit to battery voltage
00072      Fault in diesel injection
00073      Fault of diesel engine temperature sensor
00074      Load signal - short circuit to ground
00075      Torque control circuit - short circuit to battery voltage
00076      Load signal - short circuit to battery voltage
00077      Kickdown circuit - short circuit to ground
00078      Shift period to long
00079      Kickdown switch - circuit interrupted
00081      ETR signal (Engine Torque Reduction) - circuit interrupted or short to battery
00082      Selector lever position switch incorrectly - remain in last valid display and then adjust enter D mode
00083      Torque control - short circuit to ground
00084      Brake switch - remains closed
00085      Control unit fail - fault in torque control
00086      ETR (Engine Torque Reduction) - Signal frequency outside specified range)
00089      ETR signal - Control unit fault (TC not activated)
00091      MIWG signal, transmission torque increase - short circuit to battery voltage
00092      MIWG signal, transmission torque increase - circuit interrupted or short circuit to ground
00095      Winter program display
00096      Winter program display
00097      Output display
00098      Output display
00111      Barometer
00112      Barometer
So, 56 indicates a fault with the selector switch position.....so its worth checking the adjustment
mkaminski100
  • Basingstoke
« Reply #2 on: 08 July 2008, 10:00:43 »
Thank you very much good man  :y
I think he needs to clean the swith... too common in 4L30E.
« Last Edit: 08 July 2008, 10:02:49 by mkaminski100 »
