Pages: 1 [2] 3  All   Go Down
Author Topic: Traction Control/ESP  (Read 5811 times)
Re: Traction Control/ESP
« Reply #15 on: 06 July 2008, 12:11:17 »
.....not familar with carlton setup, but that would have to wait for both rears to lock before detection  :-/
I'm talking 1986 C reg 2.2 cih Carlton NOT Omega A. Apparently very rare.
yes, i know.
« Reply #16 on: 06 July 2008, 13:03:40 »
....yes, i know.
Just checking!  ;)  :y
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #17 on: 06 July 2008, 21:14:52 »
3 channel/4 channel refers to how many chamber there are on the ABS unit - 3 channel has 2 fronts, one rear; 4 channel a bit obvious.
4 channel is obviously better, but due to the individual wheel control can be used for ESP-style control as well.
If i remember correctly, 3 channel would (as TB said) would look for both rears locked up before acting on the back brakes.
The most primitive version must have been the old mechanical 2 channel on RS Escorts...belts, i ask you?!?!?
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
« Reply #18 on: 06 July 2008, 22:50:07 »
Derived from the same set-up that the Intercepter used in the 60's. At the time it was the best available although as you suggest, silly con chips had arrived on the scene by the time the Escort had arrived!  :y
« Reply #19 on: 06 July 2008, 22:54:49 »
I never looked any further than the sensor either side of the diff when just assumed it'd be 4 channel. As I say, my Mk1 Carlton had 3 sensors for its 3 channel set up so ......
Never assume .....  ;D ;D ;D
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #20 on: 07 July 2008, 14:05:29 »
ESP was available from factory since Nov.2001. I do not know which market had it as an option, but one could think that adding ESP is not that difficult; same components, jus to add some sensors? and re-program... But then again, who needs one? TC is enough to help me in the winter time :) 2,6 does not have the power to spin wheels on dry asphalt (at least not an auto, or is there something wrong with mine?)
« Reply #21 on: 07 July 2008, 14:08:20 »
Not sure if it was ever offered as a UK option.
« Reply #22 on: 07 July 2008, 14:09:07 »
also guessing it would be a replacement ABS
Dusty
  • Shropshire
  • Erotic Romance Author
« Reply #23 on: 07 July 2008, 16:30:24 »
Thanks guys. Dont pretend to understand everything you have all spoken of,but i get most of it.
You certainly know your Omegas. :y :y :y
TECHNOPUG
  • Islington - London & Essex
« Reply #24 on: 07 July 2008, 16:55:26 »
I always drive with Traction Control off, well at least the light is off and if I press the button the light goes on.
However, during some rather enthuiastic driving through Adenau Forst in 2nd gear, the TC light was flashing like mad.
So does it overide the driver when you have it OFF, if you reach a certain point of loss of traction (more so than when ON)? Or is mine just broken (light going off isn't actually turning TC off)? It was certainly sliding about a fair bit but that was more to do with the speed of the car through bends, rather than lighting the rear up via the throttle.
EFA
« Last Edit: 07 July 2008, 17:02:37 by TEKNOPUG »
« Reply #25 on: 07 July 2008, 16:59:25 »
So does it overide the driver when you have it off, if you reach a certain point of loss of traction (more so than when on)? Or is mine just broken (light going off isn't actually turning TC off)? It was certainly sliding about a fair bit but that was more to do with the speed of the car trough bends, rather than lightly rear up via the throttle.
Light off means TC ON.  Light on means TC disabled.  Light flashing means TC switched on, and your giving it a little bit too much large
TECHNOPUG
« Reply #26 on: 07 July 2008, 17:04:37 »
LOL!! Bugger, well that explains it then!
Still it was probably a good thing that I had it on in hindsight..... ;)
« Reply #27 on: 07 July 2008, 17:07:33 »
Mine stays enabled except when I want to play.  It resets to enabled at every switch on anyway
philhoward
  • Staffs
« Reply #28 on: 07 July 2008, 20:39:27 »
Granted -in the 60's most radios were still valve driven.  But in the 80's?  Must have been 10p cheaper, knowing Ford's accountants...
« Reply #29 on: 07 July 2008, 21:01:32 »
......  But in the 80's?  Must have been 10p cheaper, knowing Ford's accountants...
IIRC the electrickery type that we all now know & trust was £1000 option. The 'V' belt driven set up was £400. I don't know why those figures have stuck  :-[ probably the same reason I can still remember that s=ut+1/2atsquared  :-[  ;D  ;D
I've also read that the belt driven type was a derivation itself on ABS that was developed for planes. As planes got slimmer, the room available for the landing gear also got smaller so wheels had to become slimmer. Planes then started to burst tyres as they landed 'cos the pilots had less 'feel' of what was happening on the ground due to other assistance, so planes crashed. ABS was developed to try to help. V belt system was the best they were able to come up with untill modern systems were developed.
Entwood will probably be able to confirm or tell me I'm talking out of my 4r$e!  ;)  :y  :y
« Last Edit: 07 July 2008, 21:09:32 by Andy_B »
Pages: 1 [2] 3  All   Go Up
