Pages: [1] 2 3  All   Go Down
Author Topic: Traction Control/ESP  (Read 4989 times)
Dusty
  • Shropshire
  • Erotic Romance Author
« on: 05 July 2008, 20:14:40 »
Recently bought a 2.6 Omega.
I know it has Traction Control, but does it also have an ESP or equivalent system?
By this I mean electronics that can cut power to individual wheels and brake them in order to counter understeer and oversteer.
Or does it just cut power to the rear wheels when they spin?
Thank you
Re: Traction Control/ESP
« Reply #1 on: 05 July 2008, 21:23:32 »
no ESP on UK models.
TC only.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #2 on: 05 July 2008, 21:24:22 »
Thank you
Yup, the Omega only has t.c
« Reply #3 on: 05 July 2008, 23:35:35 »
TC only. And a bit crude as well if you ask me, but it does work.
« Reply #4 on: 06 July 2008, 00:15:01 »
As far as I understand it, later cars with 4 channel ABS (so why did my earlier Senator already have 4 ABS sensors? ;)) also use the brakes aswell to curb wheel spin if backing off via the engine ECU isn't enough.
« Last Edit: 06 July 2008, 00:15:44 by Andy_B »
« Reply #5 on: 06 July 2008, 10:52:19 »
post 98 cars apply brake to spinning rear wheel, then cut power if still slipping.
« Reply #6 on: 06 July 2008, 10:54:06 »
same reason that all abs cars do - detect locking on any wheel. earlier systems only had 3 channels so released both back brakes together if one rear started to lock ;)
« Reply #7 on: 06 July 2008, 11:16:49 »
....same reason that all abs cars do - detect locking on any wheel. earlier systems only had 3 channels so released both back brakes together if one rear started to lock ;)
My 1986 Carlton only had 3 channel ABS so why the apparent step backwards when the Omega appeared, when the Carlton/Senator ABS had progressed to looking at all 4 wheels?
GM couldn't really have saved that much by leaving a sensor off the back - could they?
« Last Edit: 06 July 2008, 11:17:52 by Andy_B »
« Reply #8 on: 06 July 2008, 11:19:17 »
....same reason that all abs cars do - detect locking on any wheel. ....
Some cheap run-a-bouts only have 2 channel ABS! ie just on the front wheels  ;)  ;)
« Reply #9 on: 06 July 2008, 11:38:14 »
The senator was a 3 channel system.
« Reply #10 on: 06 July 2008, 11:42:16 »
No it wasn't! There was a sensor either side of the diff. Off to find my Senator Haynes!  ;)  ;)
You have pm re something else!  ;)
« Reply #11 on: 06 July 2008, 11:50:48 »
It had 4 sensors to detect if a back wheel was about to skid. But it controlled back wheels together as a pair. So 3 channel. Just like early Omegas (up to MY98).  All Omegas have 4 wheel sensors as well.
« Reply #12 on: 06 July 2008, 12:00:22 »
....It had 4 sensors to detect if a back wheel was about to skid. But it controlled back wheels together as a pair. So 3 channel. Just like early Omegas (up to MY98).  All Omegas have 4 wheel sensors as well.
Go then. I'll bow to your superior knowledge!  ;) It's something that I'd just assumed when I saw 4 sensors, the face lift Mk1 Carlton did only have 3. The third was built into the top of the diff & looked at the crownwheel.
« Reply #13 on: 06 July 2008, 12:04:27 »
not familar with carlton setup, but that would have to wait for both rears to lock before detection  :-/
« Reply #14 on: 06 July 2008, 12:07:19 »
.....not familar with carlton setup, but that would have to wait for both rears to lock before detection  :-/
I'm talking 1986 C reg 2.2 cih Carlton NOT Omega A. Apparently very rare.
Pages: [1] 2 3  All   Go Up
