Author Topic: Alloy lock key  (Read 3381 times)
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Alloy lock key
« on: 08 July 2008, 18:09:03 »
The cover that well... covers the alloy has a special key to prevent theft ect. Where can i get a replacement as mine is not present and the allys have to go!  ;)
MadMark73
  • Taunton. Somerset.
  • She is a bit of an animal!!!
    • 98 3.0 Elite Estate
Re: Alloy lock key
« Reply #1 on: 08 July 2008, 19:41:29 »
The best way to get the covering plate off is to use a small drift in one of the holes in the locking screw and a hammer. A new key and locking screws is available via ebay for about £10. Hope this helps.
Re: Alloy lock key
« Reply #2 on: 08 July 2008, 19:46:14 »
The 3 prong key for my Senator's wheel nut cover had a 3 letter code, I think you need this code really if you want another to fit. An alternative is a pin punch & 2lb knocking stick or a pair of snipe nose pliers in 2 of the holes & then use a screw driver between the legs to lever the 'bolt' head round.
psychnurse
Re: Alloy lock key
« Reply #3 on: 08 July 2008, 19:53:13 »
Is a pin punch just a small elongated metal peice? similar to a scriber or the like??
Re: Alloy lock key
« Reply #4 on: 08 July 2008, 19:56:07 »
I suppose so!
Or a centre punch would do the job
Or .... if nothing else ..... I reckon a decent sized nail would do!  ;D
« Last Edit: 08 July 2008, 19:58:09 by Andy_B »
psychnurse
Re: Alloy lock key
« Reply #5 on: 08 July 2008, 19:58:01 »
 :y :y :y :y :y
Thanks matey. I was no good at woodwork at school either  ::)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: Alloy lock key
« Reply #6 on: 08 July 2008, 20:55:39 »
I was going to suggest the pair of long/snipe nose pliers...
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
psychnurse
Re: Alloy lock key
« Reply #7 on: 08 July 2008, 20:58:44 »
Yeah that may work... Im sure they will all be loose anyway, mot other thing seem to be. One is actually hanging off anyway.
JezInBrum
  • Birmingham
  • Built for comfort not speed
Re: Alloy lock key
« Reply #8 on: 08 July 2008, 22:11:34 »
Vaux do sell a new key & bolts as a set, maybe best to replace them once you have got them out. Not sure on cost though.
Also long nose pliers in the holes & using a screwdriver as a bar should do the same job for removal. Have seen it done before.
Oops missed pevious mention of that idea  :-X
« Last Edit: 08 July 2008, 22:12:38 by JezInBrum »
psychnurse
Re: Alloy lock key
« Reply #9 on: 08 July 2008, 22:14:06 »
Useful to know about new vx sets though. I may well conider that. are they TC part do you know?
Re: Alloy lock key
« Reply #10 on: 08 July 2008, 22:19:51 »
If long nosed pliers and a screwdriver pry-bar remove the locknuts so easily .. is it worth fitting them at all ??
I'm struggling to see how the pliers/screwdriver thing will undo something torqued up to 110 Nm .. or am I missing something ???
psychnurse
Re: Alloy lock key
« Reply #11 on: 08 July 2008, 22:25:43 »
A very good point enwood! Are they not ment to be anti-theft? Mind you somebody with a screwdriver at a wheel would be supicius... but would anybody notice or care in reality?  :-/
philhoward
  • Staffs
Re: Alloy lock key
« Reply #12 on: 08 July 2008, 22:29:40 »
Have to confess, i'm thinking about the bolt holding the centre cap on mine - M8 from memory.  Universal locking bolt removing sockets available at your local tyre fitter or off ebay...so as you say - whats the point??
JueV6
  • Kent
Re: Alloy lock key
« Reply #13 on: 08 July 2008, 22:31:09 »
psyconurse is talking about the security screws that hold the centre caps on if i'm reading right :y
psychnurse
Re: Alloy lock key
« Reply #14 on: 08 July 2008, 22:33:07 »
Thats right  :y
