Author Topic: trouble after rebuild  (Read 4369 times)
blootak
  • Preston
« on: 29 June 2008, 17:43:51 »
Hello peeps
my 2.0l 16v slowmega popped its head gasket at cylinder No 4
so i decided to do a rebuild having never done one before ( and thats why it took me 6 months) anyways
I'm having trouble with it running properly
The car will fire but idle's really high @ 2000 rpm, disconnect the idle control valve and the revs drop to 800 rpm
I've changed the ECM temp sesnor, crank and cam sensors
but i'm getting a "Hall sender signal fault" constantly which we believe is why its reving high
is there something i've overlooked ?
rickyboy
  • Glasgow
Re: trouble after rebuild
« Reply #1 on: 30 June 2008, 00:43:20 »
Can you do the paperclip test and read off the fault code chart in the guide just to confirm your code is the crank sensor (hall effect sensor).  If it flashes 10 times count the number as a zero.  Link below...
I doubt that's the reason it's idling high - more likely that the idle control valve needs cleaned.
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
blootak
  • Preston
« Reply #2 on: 30 June 2008, 07:07:02 »
cool i'll try the papr clip test
but mate told me to clean that valve, it seems very free, could the solenoid for be sticking ? because when i disconnected it the rev went back to normal ?
magnul
  • Trondheim, Norway
« Reply #3 on: 30 June 2008, 07:14:38 »
If it revs high I'd suggest you look for vacuum leaks.
haj
  • Brighton
« Reply #4 on: 30 June 2008, 15:47:27 »
Had this problem after cleaning breathers,throttle.Turned out i was a bitheavy handed with the outer accelarater sheath,not enough slack to adjust the butterfly valve,slackened it off ,adjusted butterfly valve to closed,almost,no probs since.
just a thought
« Reply #5 on: 30 June 2008, 15:53:25 »
Hi blootak
If you fill in your profile you might find there is someone local to you that maybe able to give you a helping hand.  :y
rickyboy
  • Glasgow
« Reply #6 on: 30 June 2008, 16:48:14 »
Is it possible the mechanical idler on the throttle body has been tampered with at some point?  If it's an air leak I'd imagine the revs would start low then climb up.
Mabye an idea to take the ICV off again, give it another clean then make sure you lubricate it.  See if that cures it.
blootak
  • Preston
« Reply #7 on: 30 June 2008, 20:15:59 »
right i've done the paper clip test and i got 92 -cam sensor fault
could my ECM be fried ?  there's no seriel label still on it
how can i tell which ECM i;ve got ?
fred117
« Reply #8 on: 30 June 2008, 20:35:00 »
hi just rebuilt my engine yesturday and today its a 2.0
i have a problem now when the rev die down i get a poping from the exhaust  can some give me a bit of help to sort it out
rickyboy
  • Glasgow
« Reply #9 on: 30 June 2008, 20:40:14 »
Very unlikely the ECM is fried.  Easy fix for this code.  You can either clean it and see if it disappears (usually does) or replace it and it will go.  Take off the spark plug cover (ecotec strip).  Take off the timing belt cover and the sensor sits in between the two cams.  Remove the plug at the top of the sensor then remove the sensor itself - clean the sensor and it's mating surfaces then re-fit.  I
f the code doesn't go then replace the sensor.  Use genuine vaux parts.
rickyboy
  • Glasgow
« Reply #10 on: 30 June 2008, 20:41:45 »
Most likely the idle control valve needs a clean.  Post a new topic for this...
blootak
  • Preston
« Reply #11 on: 30 June 2008, 21:09:22 »
cheers rickyboy
i;ve had a new sensor on it and its still finding the code
i tried wiping the code out but it doesn't seem to want to go
Could it be the reader i;m using ? and can you use the paper clip to reset the codes ?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #12 on: 30 June 2008, 21:16:45 »
just a thought
Mine did the same - changed the old engine (blocked breathers and blown HG), but swapped the throttle bodies over as it had the LPG mixer installed.  On startup, got about 1500rpm idle, which dropped to 800rpm on disconnecting the ISCV.  Turned out the throttle stop has been wound in (screwdriver slot with lock nut) to try and raise the idle to stop it stalling (didn't..).
Wound the stop out till it was clear, then back in till it just applied a little pressure to the throttle linkage and locked it back up.  Cured it...
Unless the EML light is on, you could be seeing an old code - which will take about 25 starts to clear..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
philhoward
  • Staffs
« Reply #13 on: 30 June 2008, 21:19:48 »
cheers rickyboy
Was it a gen Vauxhall sensor, or a generic replacement?  I've heard that some aftermarket ones don't quite do the job..
blootak
  • Preston
« Reply #14 on: 30 June 2008, 21:30:21 »
notsure as my the cars at me mates garage and he did the swap, i'll check with him tomorrow
it just seems strange that the fault is there even before starting the car
once its fire it rev's to high on idle and doesn;t seem to want togo over 4000 rpm
could i have two problems here, the idle control valve sticking giving me high idle and causing the cam sensor not to reset properly because its not firing right ?
