Author Topic: Speed sensitive power steering  (Read 1656 times)
Slushboxer
  • South East Cornwall
« on: 11 July 2008, 21:44:19 »
My power steering suddenly went intermittently slightly jerky when driving at about 50 mph. then cleared and now behaves like it has lost its enhanced power for parking. Any ideas please?
Re: Speed sensitive power steering
« Reply #1 on: 11 July 2008, 21:48:37 »
If loses just at low revs, tired pump.
If loses it intermittently at speed, and you're post 1998, likely to be abs ecu :(
Slushboxer
« Reply #2 on: 11 July 2008, 21:58:10 »
Thanks for your advice. Is the PS ECU the little flat metal box located behind the OS front suspension housing under the plastic scuttle with an eight pin connector.
« Reply #3 on: 11 July 2008, 22:00:00 »
Never seen a PS ECU fail.  From your symptoms, sounds like abs ecu.  If it only happens at low speed, it will be pas pump
Slushboxer
« Reply #4 on: 11 July 2008, 22:08:14 »
Thanks again.
Pump was changed with no improvement. Think you must be right with your diagnosis. do you know where the abs ecu is located.
« Reply #5 on: 11 July 2008, 22:18:50 »
Thanks again.
Side of ABS unit (under PAS resefvoir)
« Reply #6 on: 11 July 2008, 22:21:24 »
Thanks again.
Didn't know you spoke Welsh  ;D
« Reply #7 on: 11 July 2008, 22:22:21 »
Thanks again.
I promise I haven't been drinking....
Slushboxer
« Reply #8 on: 11 July 2008, 22:31:23 »
Thanks again,
I can have a good nights sleep now.
investigations tomorrow
« Reply #9 on: 12 July 2008, 09:44:39 »
if not could be servotronic power steering?
Relay behind glove box. Confirm with tech2.
