Author Topic: fault codes  (Read 1273 times)
marcbcfc
  • dorset
fault codes
« on: 13 July 2008, 12:37:09 »
Hi,
everyone can anybody shed some light on the fault code 135 on the motronic ecu ive got a 2.5v6 1997 and on looking at the code from the great lists that someone has produced it says check engine lamp (fault code lamp) low voltage
not quite sure what that means . At the moment i have a problem eith a knock sensor,the  wiring is a biot fraid so at the moment it rgeisters a fault with the eml light staying on would this be related to the code 135
many thanks for any help
Marc
rickyboy
  • Glasgow
Re: fault codes
« Reply #1 on: 13 July 2008, 15:31:20 »
I had the check EML code for a while and it was appearing along with another code.  It's now gone after clearing the other fault code.  I think that it sometimes appears because your EML light has been on for so long.  The bulb may be getting a bit tired but if you sort the knock sensor I'm sure it'll disappear.  If not change the bulb but you probably won't need to after the knock sensor is fixed.
« Last Edit: 13 July 2008, 15:34:02 by rickyboy »
marcbcfc
  • dorset
Re: fault codes
« Reply #2 on: 13 July 2008, 15:35:47 »
Thanks mate il give it a go
marc
Re: fault codes
« Reply #3 on: 13 July 2008, 21:49:34 »
ignore the 135 code ;)
Page created in 0.026 seconds with 20 queries.
