Author Topic: 2.5TD FAULT CODES  (Read 2992 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
2.5TD FAULT CODES
« on: 07 July 2008, 22:17:38 »
My tractor is not running correctly - revs slow to pick-up after gear-change. EML is on permanently.
Local garage used a Bosch computer to read-off three codes.
They are:
92 Driving speed sensor control device open circuit/positive short
81 Needle sensor open circuit
82 Needle sensor faulty
Anyone able to help a frustrated tractor owner? - I'd be most greatful chaps!
Re: 2.5TD FAULT CODES
« Reply #1 on: 07 July 2008, 22:19:27 »
sounds like the leccy connector on injector no 4 is unplugged or wiring damaged.
« Reply #2 on: 07 July 2008, 22:21:34 »
That bosch reader gives come 'dangle berries' text.  92 just means you aint got a cruise stalk.
Seth
« Reply #3 on: 07 July 2008, 22:34:29 »
Yep - you're spot on ....
Mine's a GLS with no cruise-control.
I'll have a quick gander at No.4 injector tomorrow. If nothing's obvious, then it'll be back to the geezers who changed the injection pump post haste!
Now you can see why I'm hi**ed off. It ran really well after the pump-change, (a tad over £1200), so I expect it to be on top form at this kind of expense.
Where does this sensor wire go to - do you know?
Seth
« Reply #4 on: 10 July 2008, 13:55:14 »
Took the tractor back to the injection people .......
No.4 injector (start of injection sensor) is at fault.
Awaiting a new one - anyone got an idea of how much it's gonna cost?
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #5 on: 10 July 2008, 16:24:47 »
A lot of money
I have a full set of 6 injectors which were tested OK by Bosch Agent in Newbury if you are interested
IW
« Reply #6 on: 10 July 2008, 21:46:35 »
A shit load.
Can you repair damage to cable?
My only spare I gave to Omegatoy
Omegatoy
  • UK
« Reply #7 on: 11 July 2008, 08:23:45 »
A naff load.
nope you forgot to!!!!cos we broke injector socket :o unless you gave it to Chris at meeting???
« Last Edit: 11 July 2008, 08:24:36 by Omegatoy »
« Reply #8 on: 11 July 2008, 09:15:52 »
A naff load.
I think I did give to Chris...
Thats 2 of my injector sockets you broke, hooligan ;D
Omegatoy
  • UK
« Reply #9 on: 11 July 2008, 20:35:11 »
A naff load.
well if you will buy cheap tools :o :-X
Seth
« Reply #10 on: 12 July 2008, 22:40:25 »
LATEST TRACTOR NEWS:
Got the car back today - The Boy was spot on.
No.4 injector (start of injection sensor) was totally naffed.
Fuel injection people have changed offending unit, and now performing really well ....
Time for some good luck now gents! ...... and thanks to everyone!
markey mark
  • SLady bitshorpe north lincs
« Reply #11 on: 13 July 2008, 01:25:31 »
now chip the bugger ! :y
Seth
« Reply #12 on: 13 July 2008, 13:17:21 »
Where can I get a chip?
What will it cost?
What BHP will it give?
« Reply #13 on: 13 July 2008, 21:52:27 »
What will it cost?
via me or omegatoy
iirc about £70ish
Back to around bmw spec
350sb
  • London
    • X reg 2.5 TD GLS
« Reply #14 on: 14 July 2008, 15:03:09 »
Does Omegatoy have a website were we can see more details like a dyno test,etc?
